Greg Rozar AKA- CubDieselFan
Old 09-13-2018, 10:08 PM
CabinCub2002's Avatar
CabinCub2002 CabinCub2002 is offline
Default Carburetor issues, need advice for this weekend
Hello everyone:
I’m trying to get a old 1967 International Harvester Cub Cadet 102 up and running again at my cabin on my family’s property. It has been sitting for about 10 or so years and I have already done a oil change and emptying out the old gas. The problem I seem to be having is the carburetor won’t send fuel to the engine even though I put new fule in the tank. This weekend I plan on putting new gaskets on the carburetor to see if that will help but I’m not sure what else to do if you have any advise that would be helpful.
File Type: jpg BFC96BCA-BCA8-420E-8095-893E4E43190A.jpg (24.6 KB, 83 views)
Old 09-13-2018, 10:11 PM
Take the carb apart and put a kit in it. Rebuild as necessary. Unless you can get lucky and find one locally, you won't get a carb kit by Saturday.
Old 09-13-2018, 10:15 PM
Default Thanks for the advice
Thanks for letting me know I’ll try cleaning it with a bit of carb cleaner first and if not I’ll get be sure to get a rebuild cut for next weekend.
Old 09-13-2018, 10:20 PM
Originally Posted by CabinCub2002 View Post
Thanks for letting me know I’ll try cleaning it with a bit of carb cleaner first and if not I’ll get besure to get a rebuild cut for next weekend
No.... you don't understand. Carb cleaner isn't a "fix in a can".
You have to take the carb COMPLETELY apart to get all the dried up crap out of the passages. You need to pull the emulsion tube out. You need to take the needle valve base out. You have to pull all the adjusting screws out. Then you have to make sure all the passages are free and clear. You will tear up the bowl gasket when you remove it. Even if you don't, it won't ever seal up again. It would be a complete waste of your time to disassemble the carb and try and "fix" it, just to put it back on and try it..... then order a kit, and do it all over again next weekend. Go order a kit, go take the carb off and soak in a a dip bucket of cleaner, take the time to do it right, and be done. If this sounds too time consuming, then just order a new carb from China for $35 and put it on.
