Greg Rozar AKA- CubDieselFan
Closed Thread
Old 09-14-2018, 11:51 AM
Mudrig150 Mudrig150 is offline
Default Muffler leak
I need help fixing my exhaust, I have a bad exhaust leak. The muffler sits nice and snug on the muffler elbow, but the flange on the exhaust is broken off and the hole is deformed. I've heard to cut the top off an aluminum can and wrap it around the muffler to seal it. Any other tips? TIA.
Diagram of how it's like on the elbow:
Before you yell at me for excluding the baffle, it's broken and I don't want to break it further. It'll be welded soon, but I need the tractor out from its corner behind a bale.
Old 09-14-2018, 01:15 PM
Muffler is broken. Missing a piece. Get another one. You won't stop that leak.
Old 09-14-2018, 01:33 PM
That's part of the problem, the other part is probably that I'm using a 1.5" clamp on a 1" outlet. I need a new clamp. Even if the muffler was fine I'd still need a new clamp because the original one has the one side snapped off.
Edit- Isn't the outlet 1.5"? I could get a 1.5" clamp, and I think the one I'm using is actually 2", from a JD 318.
Old 09-14-2018, 02:29 PM
Get a new muffler and the correct clamp. If you are going to go with a "cobble job" then you are on your own.
BTW: Aluminum can...........Bad Idea.
Roland Bedell
Buy: Made in the USA
Old 09-15-2018, 09:10 AM
ironman's Avatar
ironman ironman is online now
Duck tape! It fixes everything, and it will enhance the quality of the other work you do.
Old 09-15-2018, 09:12 AM
cooperino's Avatar
Its spelled Duct tape LOL.. I have not ever used it on hot exhaust . Should make for an interesting smell! lol
Old 09-16-2018, 05:27 PM
ambrola's Avatar
ambrola ambrola is offline
What he said.
Old 09-16-2018, 08:13 PM
One final attempt, haven't tested it yet but I'll get some aluminum tape to seal it. Need to drill out a hole in the block for the bottom baffle bolt. Realized that my carb side engine tin is broke in half, so need a new one of those. This just keeps getting worse.
Just need to throw the engine tins back on and seal it all up.
If this don't work, I'll just buy a better muffler.
Edit: Figured out my muffler was brute forced off the elbow, so that's why it's broke.
Old 09-16-2018, 09:58 PM
Do you know why they don't make mufflers out of aluminum?
You need to start listening. I think someone made that comment in my "kid" thread the other day.....
I doubt it. I've chiseled mufflers off with an air chisel and didn't hurt them. I doubt someone "brute forced" it off and broke it. It was likely cracked from vibration, and broke when removed at some point.
Get another muffler.
Old 09-17-2018, 06:55 AM
Leadslingingdaddy's Avatar
How about the CORRECT Muffler....??!!
Closed Thread
