Off Topic: B&S motor
Well, I have a Made in Canada Roper tiller w/ B&S 4hp. motor. In order for me to shut down the motor, I should pull the choke, or I can ground out the spark plug. With a metal tab attatched to a headbolt, I simplt bend it over to meet the top of the sparkplug and thus, fouling out the plug. Seems like I'am going through sparkplugs doing this. Is this a good way to shut down the motor....or would be choking it off be better??? Of course my model dont have a shut-off switch. Thanks, John
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
back in the day the metal tab to the spark plug was standard from the factory to shut down a lot of the engines, i would bet that owners getting zapped by touching the plug was the prime motivator in having a kill switch to replace the tab.
I would short the plug,thats proper as stated previously.
Pulling the choke floods the motor a bit with gas, upsetting the mixture and chocking off the air,causing it to stall. ---- just not a good thing to do. Slow the engine (any engine) to idle for a minute or 2 after use, and then short the plug. ---listen real close and you will hear the engine say "thank you" |
Yup, what ol'George said.
I'll 3rd that. If you pull the choke to stop it, you are washing the cylinder walls with raw gas every time you shut it off.
Thanks Guys! Got it all cleaned up and back togeather.
