best way to "hold" an engine?
I'm getting ready to take the engine out of my 127 to paint it and the frame. What's the best way to hold/stabilize the engine while removing it? I was thinking about putting a car jack under it but I also need some way to "hold" the engine so I can take the metal off and paint it...
Gary '49 Farmall Cub, '62 "Original, '70 73 w/402-D Haban sickle, '71 127 w/38" cast end deck, '73 149, '76 Sof76, '07 LT1045 w/bagger, '09 GT2544 w/bunch of mods. 5 Exmarks, Kubota B2920, blah, blah, blah... |
Got an extra small floor jack lying around that you never use?
If you (or anyone else) wants to make one, let me know so I come up with appropriate minimum sizes for the boom material, as it's very important that it isn't sized too small. |
the best way to hold/stabelize it would be 1 hand on the front and 1 on the back, thats how i do it, then put it on the bench and put a block of wood under it.
To much to list! |
Matt, I got one just like that that is too small to use on anything outside of GTs...
You could anything you want. I even have a bad back and I was able to pick it up by hand. It's not as heavy as you would think! It is awkward though.
thats what i was getting at, a hand on the front pto, and 1 on the back pulley and i pick it out and put it in my kids wagon and take it where it needs to go, it is a bit awkward but its not heavy! I no what u mean about the back, 5.9 same boat here!
To much to list! |
Gary, I picked up a cheap harbor freight chain fall, and pull my engines using that. I'm lucky enough that the previous owner of my house installed a 6 x 6 across the rafters in the garage from one wall to the other to lift his race car engines. I suppose a tree could work as well. I have a roll around lift table that I drop it on with wood blocks on it spaced apart to straddle the oil pan.
Before I picked up the chain fall, I just man handled them out swinging them up on my workbench...its doable, but easier with a little mechanical help. Jeff (teet)
CCC 1211 71 127 102 122 1962 Original |
I guess really what I want is something that can handle the engine while I spray it. I didn't know if the oil pan on the 12hp kohlers were flat enough to sit up or not by themself. I'm capable of "handling" the engine. but I am getting to the age where I'm growing out of my young stupidity too... The days of "watch this boys!!!" are coming to a close the quicker that 30 gets here.
What Matt has would be perfect, I had something envisioned in my mind using a similar small jack and some type of cradle that the sit would just sit in and be happy for a while, jacking it up from the bottom like usual.
I think I know what you mean now Gary, I made up a "cradle" to hold my engines while they were out. It was just some scrap 2 x 6's and some threaded rod, so I could adjust the width to cradle the oil pan...
Jeff (teet)
