Greg Rozar AKA- CubDieselFan
Old 09-04-2018, 06:29 PM
john hall's Avatar
Default lt1050 drive belt
OK, helping out someone in need---they got hurt in a car wreck and lawnmower quit working while family was trying to keep the grass cut. If any of you know, can the hydrostatic drive belt on a LT1050 be changed by just dropping the PTO clutch? How about the back end, assume it lifts up over the fan. Just trying to see how big of a job I have before me. Also, is the transmission serviceable as in filter and oil change, or is this a sealed unit?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 09-05-2018, 08:07 AM
ironman's Avatar
ironman ironman is offline
With the deck removed and the PTO dropped down you can work the belt up and around the fan onto the hydro pulley from underneath. It will be much easier if you can lift the tractor to where you can get underneath it.
On the transmission, I think it is a Hydro Gear 0510 and therefore not serviceable, but look at the tag on the housing and if it's something else here is a link to their manuals.
http://www.hydro-gear.com/service-and-repair-manuals/
Old 09-05-2018, 12:17 PM
john hall's Avatar
Thanks! just wanted to make sure I didn't have to pull the engine. Hopefully PTO will slip right off.
2072 w/60" Haban
Old 09-07-2018, 06:31 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
if the PTO doesn't slide right off there is a hole in the frame you can stick a long punch or similar that gets you close to the shaft, a couple taps on the punch and it'll drop right off
I saw it on a youtube video just search for "lt1050 pto"
put some antisieze on the shaft and next time it'll be even easier
rest of the job was a breeze
JD x475
