Greg Rozar AKA- CubDieselFan
Old 07-31-2018, 08:20 AM
I really need replies from the OP, not you, to help him find a solution. I can read what he wrote just fine, thanks.
Prolly wish I didn't reply,-------
but are they like the other electric clutches, that a locked bearing causes a
run-on condition?
Old 07-31-2018, 08:24 AM
run-on condition?
It could, yes.
Old 08-21-2018, 04:47 PM
johnc johnc is offline
Default I am back
2145 blades now run all the time when motor running
Have replaced relay and pto switch with no help
Again makes no difference if the pto switch is on or off
Any suggestions are appreciated before I take to shop
Thanks
John
Old 08-21-2018, 04:58 PM
cooperino's Avatar
Thanks
John
If you remove the power wire leading to the PTO does it still stay engaged? If it does then I would say the suggestion that the bearing is seized is correct. You need to remove power from PTO and check that.
Old 08-21-2018, 06:22 PM
What he said, unplug the wire going to the PTO and if it continues to make the blades turn you have a bad bearing in the PTO. If that is the case I suggest that you replace the PTO and be done with it unless you are OK with rebuilding your PTO.
Edit: These guys are our recommended go to when it comes to replacement PTO's
https://www.onlycubcadets.net/forum/...ad.php?t=45466
Old 08-23-2018, 02:46 PM
Default Bearing seized
Thank everyone for help.
Unplugged power to pto and blades still turned with motor running
Have a onan elite mother do I need a certain nomenclature for the onan motor?
Thanks
John
Old 08-24-2018, 10:38 AM
John I would plan on replacing the PTO, Cub part # is 717-3385 P.T.O. Clutch
This is a Google search so you can pick who you get it from
https://www.google.com/search?source....0.B7aRlakT8js
I've used these guys for a couple PTO's with good success.
https://xtremeope.com/p/xtreme-repla...SAAEgJKVPD_BwE
Old 08-24-2018, 12:28 PM
Default Thank you
Thank you for all help
Have not been to Galax in forty years remember being a nice and friendly town
Old 08-24-2018, 03:56 PM
Too many people doing Meth here now.
Old 09-07-2018, 10:39 AM
Default Replaced pto
Appreciate very much all the help on the 2145.
Ready to mow!
John
