Greg Rozar AKA- CubDieselFan
Old 09-14-2018, 09:45 AM
Originally Posted by Wayne View Post
How much if any play should there be in the brake disc? When its mounted with the wave washer and C clip I can depress the edge easily several mm if not a 1/4 inch. I really dont want to spend another $40 if that play is normal or acceptable.
If you just press on the edge, it will deflect..... normal.
Focus on the things I told you to check.
Old 09-14-2018, 06:11 PM
Wayne Wayne is offline
I did those before you even asked. I'm using the correct thrust button. I've got the compression springs on the screws just in front of the back plate, where they belong. The bearing is flush with the end of the crankshaft, and there is no shine on it. There is no shine on the rear of the tension springs.
I dont think its even possible to put the pulley on the crank too far, because it stops when it hits the bearing and the bearing is on the end of the crankshaft where it should be.
But I have to wait until at least Tuesday when I get a starter bracket to run it again
Cub Cadet 2166
Old 09-14-2018, 06:41 PM
Then either you didn't use the tool correctly, or didn't adjust the engagement rod correctly. Like I said, pretty simple set up.
Old 09-15-2018, 08:58 AM
ironman's Avatar
ironman ironman is offline
I probably am reading this different than what you mean but just to be sure, do you have the springs between the plate and the pulley, like this?? These are pics of a non-brake PTO but they work the same.
Old 09-15-2018, 10:29 PM
yep, they are exactly like that ironman. Thanks for posting the pic and asking.
Cub Cadet 2166
Old 09-21-2018, 11:41 PM
Welp I got my new starter bracket and redid the clutch yet again, and everything seems to be working normally. Mowed for almost an hour today and the clutch and brake work as they should. It took a while but my expenses were minimal except for the place that charged me $12 for shipping on 2 wave washers.
Thanks for Ironman and several others for their encouragement and help, and thanks to the others for thinking I'm too dumb to do it.
Cub Cadet 2166
Old 09-22-2018, 10:02 AM
Inspector Gadget Inspector Gadget is offline
Wayne, glad it’s working for you. Were you able to determine what was causing the problem?
Old 09-23-2018, 02:05 PM
I think the most likely cause is that the spring plates were permanently deformed and had lost their spring. They remained concave when I took the old ones off. So the last time I used the brake, the plates probably remained depressed and didn't spring back so the pulley wouldnt turn after that. Make sense?
Cub Cadet 2166
Old 09-23-2018, 03:23 PM
cooperino's Avatar
Enlighten me. How does it stop without the brake?
Law of physics. Nothing to keep it turning once its not engaged. Plus the blades and belt help slow it down
