Greg Rozar AKA- CubDieselFan
Old 08-07-2020, 06:47 AM
IHinIN IHinIN is offline
Built a simple boom pole that I’ll use to set some 2x12s when I build a loft in the back of my barn. It reaches up 11’ 2”. It will accept a pulley in case I decide to add a winch to it.
File Type: jpg 093A61E1-7C57-4F1B-9ED8-F2D04C76165A.jpg (28.4 KB, 208 views)
File Type: jpg FFD60C27-2F1F-475E-958A-49D63BA63238.jpg (35.1 KB, 210 views)
Old 01-27-2022, 09:53 AM
My latest Kub project is a winter cab. I probably should have started it before winter but so far we haven’t had enough snow to need it. It’s mostly done other than a few small pieces in the back and the plexiglass windows. The rear panel will be quick detach in case I need to use the backhoe with the cab on. The doors also lift off.
File Type: jpg 613B3BC3-3FDA-4D48-A3D6-5625FEA32BD7.jpg (33.1 KB, 189 views)
File Type: jpg 977A10C6-37D7-4446-8C96-2CDD4599A03E.jpg (27.8 KB, 187 views)
File Type: jpg F4F4A3A8-50E6-4880-8335-7B87895B34A8.jpg (34.1 KB, 187 views)
Old 01-27-2022, 06:13 PM
Nice wood work, are you going to paint it with bed liner to keep the moisture out?
Up to 530 and counting...
Old 02-05-2022, 01:24 PM
Thanks.
I probably will use bedliner paint. I’ve thought about painting it orange but the bedliner would hold up better since I’ll be removing the cab in the spring and storing it in the barn.
Old 09-18-2022, 09:32 PM
Cab is nearly complete. Finished installing the last window today. All that’s left is to add seals along the bottom of the doors and plumb my homemade heater. I painted it with spray-can bedliner.
File Type: jpg 677B7A5F-9657-41BF-8CB7-C7D454D791E5.jpg (34.6 KB, 111 views)
File Type: jpg B1D8BDCA-7B7B-419A-A377-D9E4F3E2557A.jpg (32.4 KB, 112 views)
File Type: jpg 691130BB-33AF-49BA-B241-8FD1B7B0F090.jpg (29.9 KB, 110 views)
Old 09-19-2022, 08:14 PM
SWEET!
Old 09-20-2022, 05:39 AM
SWEET!
+1 on that!
Okay Adam, what's that heater and how does it work?
Old 09-20-2022, 07:03 AM
+1 on that!
It’s a homemade contraption of course. I don’t know how well it will work yet. I still need to plumb the hoses to the engine.
It consists of an old brass transmission cooler that I pulled from a radiator tank inside a 4” HVAC duct. There is aluminum gutter guard mesh fan-folded and stuffed around the transmission cooler as heat sink fins. Below that is a 6” fan. The defroster and heat ducts are 1-1/4” PVC.
Old 11-16-2022, 08:19 PM
Plumbed the heater with a 3-way selector valve to allow the heater to be bypassed in warmer weather. It doesn’t put out a lot of heat but it should keep the windows clear and my fingers and toes warm.
File Type: jpg 98F01792-AB65-4EEE-9CBE-8C6B265E310D.jpg (37.0 KB, 64 views)
File Type: jpg D9CE626A-C3CA-4401-B59F-3C234CD2E113.jpg (31.1 KB, 64 views)
File Type: jpg 80B2A058-313F-4870-AED9-1678FC852DF8.jpg (37.1 KB, 64 views)
Old 11-17-2022, 10:06 AM
Sweet setup Adam. I made a vinyl cab for my BX. Got some 30 mil vinyl from marinevinylfabric.com pulled the edge molding off the cab shield, clamped the vinyl on then put the molding back on with a couple zip ties to make sure it stays in place. Just trying to block the wind.
