Greg Rozar AKA- CubDieselFan
Old 02-12-2019, 11:12 AM
Leadslingingdaddy's Avatar
Break out the Voltmeter....
Old 02-12-2019, 11:40 AM
jebow2 jebow2 is offline
Don't forget about the pto switch. Is the pto switch in the off(down) position? Tractor will not start if the pto switch is not in the off position. Looking at the wiring schematic for the 1872 the seat switch does not need to be closed for the tractor to start, just the brake pedal switch needs to be closed. It is possible that the pto switch is bad or it has bad connections. In the off position there needs to be continuity between terminals 1 and 2 at the pto switch. You might try wiggling the connection at the rear of the pto switch while having the key switch in the start position and see if the tractor will try to start. Pretty simple start circuit. Just get your voltmeter out and follow voltage through key switch, pto switch , brake switch to the small terminal on the start solenoid. Reference everything to chassis ground(-) and make sure the start solenoid is well grounded.
Old 02-12-2019, 12:23 PM
Gr8lite Gr8lite is offline
Thanks guys ...... I'll poke it with the ole meter .....tomorrow as I forgot I took it home for something.
Yea checked the PTO switch , the brake switch is not a part of this tractor anymore , someone before me removed it. I may make an attempt to put one back on .
Thanks !
Old 02-12-2019, 12:34 PM
In order for the engine to roll over, two things need to happen.
* PTO Switch needs to be in the OFF position
* The LH Brake Pedal must be depressed.
Now, this is assuming that the above switches are correct, functioning correctly, and wired correctly.
Roland Bedell
Buy: Made in the USA
Thread Tools
Display Modes
