Greg Rozar AKA- CubDieselFan
Old 02-08-2019, 08:05 AM
Originally Posted by Vrobert View Post
I think there are 3" rods welded in each end. The bent rod is on the sprocket side. The rod is about 1" thick so I expect the weld or something other than the rod is actually bent.
With the chain off, you should be able to see what is bent when turning it over by hand.
it might be the just the stub axle that is bent,
the auger tubes are pretty stout, but there are always exceptions.
If it is beyond your abilities/want to fix it, those throwers pop up frequently. Some look pretty rough or are not complete and can be had inexpensively for parts.
Old 02-08-2019, 11:03 AM
Billy-O's Avatar
Billy-O Billy-O is online now
I suspect you have a bearing problem other than a bent shaft.... but do take a look. I can't imagine a 1" stub of a shaft getting bent. Unless the thick steel hub at the end of auger got cockeyed.
On my QA-36, there were no welds on the shaft when I needed to pull the shaft out for repairs..... but do figure a pissing match freeing it up.
Plow blade
#2 Cart
QA36 snowthower
