Greg Rozar AKA- CubDieselFan
Old 10-20-2018, 04:37 PM
mellowyellow86 mellowyellow86 is offline
Thanks for the tip. I am new to forums and I am trying to figure this one out.
I am sure I most likely got something out of sequence. I will give it another try tomorrow. I am not sure what format my photos are. I will check that later.
Please bear with me while I learn. Your helpfulness is appreciated.
Thanks cooperino!
Old 10-20-2018, 05:08 PM
cooperino's Avatar
Thanks cooperino!
Anytime!
Old 10-21-2018, 07:39 PM
my 86 as purchased in July, 2018
Old 10-21-2018, 08:27 PM
cooperino's Avatar
Clean looking 86 !
Old 10-21-2018, 10:22 PM
It's been washed on the surface, but there is a lot of gunk on the engine and frame.
don't know much history on it but it runs good. I had to replace a head gasket and now I am replacing the brake lining. would you know what thickness the original brake pads were?
I am using 3/16" but I think they will be too thick.
Old 10-21-2018, 10:28 PM
More pics if the engine.
Old 10-22-2018, 07:58 AM
cooperino's Avatar
I do not know the actual thickness of the material. I think the closest material available is 3/16 which might need to be a bit thinner.. Check out this PDF on relining cub pads.
http://home.earthlink.net/~stanner42...rakeReline.pdf
Old 10-22-2018, 09:08 AM
I used 3/16 but had to sand the pads down on a belt sander to get them to fit.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-22-2018, 09:19 AM
That is a good tutorial. I saw that the other day and have already started on it.
I have the pads made, so now I have to set the drill press up to mill them. It sounds to me like it's kind of a trial and error thing on the thickness.
I will send some pictures when I get it done.
Thanks for the help!
