Greg Rozar AKA- CubDieselFan
Old 01-03-2018, 01:08 PM
yettrbomb yettrbomb is offline
Default Old Pump
Anyone ever seen anything like this before? This was in the attic of my grandmothers garage, found when we were cleaning out after she moved in with my aunt. It belonged to my grandfather, he passed away many years before I was born. I know he used to have a large garden. My dad said he had a David Bradley tractor with lots of attachments, but was sold years after he passed. He also thinks he may have used this pump with either his lawn mower or the DB. But no one knows for sure. It spins freely, and I’d like to try and use it, even if it’s just once. I’d guess it’s from the ‘60s. Little to no info online. Any help is appreciated! Thanks!
File Type: jpg BF988EBE-27C9-4663-AE57-0EBBF6E401C7.jpg (26.7 KB, 114 views)
File Type: jpg 674E2763-E08C-4A1E-BDC6-A019767E1E47.jpg (20.9 KB, 112 views)
File Type: jpg 4996A33E-65D1-4D0A-B7C9-43C9B45A143B.jpg (23.6 KB, 112 views)
Old 01-03-2018, 03:57 PM
Terry C's Avatar
Terry C Terry C is offline
Hard to say who made that for Sears. Better lube that seal up good if it’s been sitting. I can’t tell what packing it has but have water in it before you spin it up.
Hope it still works.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 01-03-2018, 07:49 PM
[QUOTE=Terry C;443210]Hard to say who made that for Sears. Better lube that seal up good if it’s been sitting. I can’t tell what packing it has but have water in it before you spin it up.
Hope it still works.[/QUOTE
Heard that! If it warms up here I will put some water to it. Gotta find something to couple it up...
Old 01-03-2018, 08:25 PM
RLause's Avatar
RLause RLause is offline
The pump will need a foot valve or a check valve in the supply line because the pump will not pump air. Without water to cool and lube the seal, it won't last very long.
Richard
Old 01-03-2018, 08:30 PM
Can you get a close up of the tag?
Thanks
Jeff
Old 01-03-2018, 08:43 PM
Yes, for sure!
Old 01-03-2018, 08:47 PM
[QUOTE=Jeff in Pa;443236]Can you get a close up of the tag?
Thanks
Jeff
Yes I did get another one. Having trouble uploading, will try a little later!
Old 01-03-2018, 09:04 PM
[QUOTE=yettrbomb;443239]
Thanks
Jeff
I'm having a terrible time uploading pictures lately. They are always "too big" even though I resize them.
Loading off the computer sometimes works better than from a link
Old 01-03-2018, 09:06 PM
Also, found a company “Ace pumps” are making one really similar to this one. I’m gonna send an email to see if they maybe made them for sears.
File Type: jpg 2AB85387-1E24-4264-B700-14A946AF77A3.jpg (24.8 KB, 79 views)
Old 01-03-2018, 10:03 PM
A foot valve is what goes onto the end of the hose/pipe that goes into a well.
(Most common application.) It is so the pump doesn't lose prime. He never said he was going to use it to pump water out of a well. If he uses it on a tank, or feeds it overhead it will be fine. As long as you aren't trying to suck water up a 20' column, you don't need a foot valve.
Ace pumps have been around for a long time. Don't know if they will help you or not... but they do make similar pumps.
