#21
Well now that really muddies the water,
I did more tests. I found another amp gauge that was a little more accurate and sensitive. It showed that when putting the plate on the coil, that it did decrease amp draw but was more of a quick fluctuation and barely showed a difference in draw. So I did a temp check, after an hour, it got too hot for my dainty hand to touch @ *130 with plate to coil, using just a dial temp gauge I use for ac work not a calibrated one. What surprised me was with driven plate removed mimicking a large, out of speck air gap, after another hour passed, no magic smoke and the temp at the same *130 as the previous test. So have I busted another myth, or just created more questions? Important thing is op has a working pto with no cost. |
#22
If your engine is at full throttle you should show a charge, not a discharge on the gauge. Now I'm going to a quiet corner and take up drinking, fall asleep and dream of something exciting. |
#23
I agree with this completely. I was wondering the same thing.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
Thread Tools | |
Display Modes | |
