LTX1050 - Can't get gas tank back in
I am a new member in a heck of a bad shape, am DESPERATE and BEGGING FOR HELP!!!!!!
2009 Cub Cadet LTX1050, Kohler 22hp. This morning I went to take the plastic cover off the engine to check for nests, bad wires etc. The only way I could seem to get it to come off was to remove the gas tank. I worked it out of there sure enough, but I ABSOLUTELY CANNOT GET THE GAS TANK BACK IN!!!!! Now I have the fan off the top of the engine and the tank STILL WON'T GO IN! At this point I am ANGRY, and I mean ready to EXPLODE!!!!! This stinking damn bloody piece of crap WON'T GO BACK IN THERE NO MATTER WHAT I DO!!!! For god's sake, can ANYONE PLEASE TELL ME HOW TO GET THIS GAS TANK BACK IN THERE?? PLEASE.....ANYONE WHO KNOWS HOW.....PLEASE tell me what I need to do. I MUST get this thing running IMMEDIATELY and I am ABSOLUTELY DESPERATE!!!!!!!!! EMERGENCY!!!!! PLEASE help me!!!!! What a way to introduce myself. |
Ugrent request for help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!
Please help me urgent urgent urgent urgent please i need help immediately please please please please please please please please i am desperate help me help me help me please!!!! Please help me!!!!!!!!!!!!!!!!!!!!!!!! |
What seems to be the obstruction? Can you snap a pic of it with the tank in as far as it will go illustrating whats stopping it?
THANK YOU for replying. Here's a pic. This any good? It's hitting the steering shaft and the dash itself
Im assuming it needs to turn left by 90 degrees yes? If the engine is keeping you from doing so you could unbolt the engine. However, logic would suggest if it came out it should go back in. Did you forcefully pull it out? Or did it slide out easily?
I think I could get it back in if I could get the dash to tilt back, but the bolts at the bottom are covered up by the chassis. |
Well,. One idea. Its plastic. It should flex a bit or bow inward. However it would be harder to do that with the cap on keeping it from "shrinking" for lack of a better term. Im guessing the correct way to do this to begin with was to loosen or remove bolts holding dash to allow more clearance.
Other option is pull the four bolts holding engine. They are pretty accessible. Maybe even loosen front 2 and remove rear 2 might do the trick with engine tilted a bit forward
I CAN'T be the first one to remove a gas tank on this model. Someone HAS to have done this before |
