Greg Rozar AKA- CubDieselFan
Old 04-06-2019, 04:45 PM
Jonjon431 Jonjon431 is offline
Question LT1045 (2008) Blowing fuses
I have a 2008 cub cadet lt1045 with the SV600 motor that keeps blowing fuses. I've been trying to find the issue but have not had any luck and would just like to completely rewire it as the previous owner said the wires started on fire and he said it was still running, Its also been sitting outside for over a year after that and I believe this is the issue. Does anyone know where I can purchase all of the wiring and harnesses at?
Old 04-07-2019, 08:41 AM
You will need 925-04402A Wiring Harness.
Roland Bedell
Buy: Made in the USA
Old 04-13-2019, 07:04 PM
Is the 925-04402A harness interchangeable with the 625-04094 rev 2 harness? I went to a local lawnmower place and they ordered and gave me this. The PTO replay and switch plugs are not the same.
Old 04-13-2019, 11:31 PM
Since they are different Part Numbers, it was safe to assume NO, they are not the same.
Roland Bedell
Old 04-14-2019, 01:21 PM
Roland gave you the part number that is listed for a 2008 LT1045, whoever sold you the other one gave you the wrong part.
Cub parts site. https://www.cubcadet.com/equipment/A...c-4057c176e095
Scroll to the bottom of the parts numbers.
Old 04-22-2019, 06:46 AM
lyoneyes lyoneyes is offline
I just bought an LTX1045 only because I needed the hydrostatic for my LTX1050. Don't know much about the 1045 specs as I was only interested in the transaxle. Was told it has a bad Kohler engine with low hours. I was able to turn it over. The flywheel housing is gone, so I'm assuming he told me correctly. I've only had this thing around since Saturday. Got my LTX1050 going now so the plan to strip it down and move it on out of here ASAP. I'll grab the wiring harness. If yours has the Kohler engine, my guess is it will work. Let me know! Edit message: Wanted to add that this 1045 has a manual PTO lever and not the electric clutch. As I said, not very familiar with the 1045 other than I knew it had same transaxle.....
