1020 differential grease
I'm a new guy here, I purchased a one owner 1020 that wouldn't move, it turned out to be a stripped spline in one of the couplers on the pump. The housing is filled with grease, what type of grease should I use to replace the old grease?
Cub parts site calls for 16 OZ of Darina Grease. I have no idea what Darina grease is.
https://www.google.com/?gws_rd=ssl#q...nsmission**+++ Edit: Looks like it's a Shell product. Here is some info. https://www.google.com/?gws_rd=ssl#q...+Darina+Grease
thanks, I found that is a clay based grease. I have found what I believe is a correct replacement for the Shell Darina grease. It is from McMaster Carr, it is a clay thickened high temp grease, part # 1062K88 (5lb. tub for about 30 bucks. The Darina grease I found was about $20 for 8oz. I needed around 19 oz.
OK, hope what you are buying is correct.
differential grease
Me too, I'll do a comparison when I get it.
