Front Blade
Anyone use a front blade on their LT? I'm ordering one tonight for mine. This shoveling stuff is getting to be too much for the old guy.
I think this front blade http://www.homedepot.com/p/MTD-46-in...mtd+snow+blade and a set of chains for the rear and hopefully I'll be in business. Could have used it this morning. We got 3-5" total. Anyone have this setup? |
The best advice I can give you about plowing with an Lt is to not let the snow get to deep, plow it every couple inches so you don't have to push to much at once.
You may want a I get some wheel weights also. A LT weighs a lot less than a GT . If I didn't have weights on my 1211 it would have a hard time with 42" blade.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
Agree with both poster!
The plow you looking at has no undercarriage framing, those are just good for very light duty, that's what LT are build for.
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
I wouldn't put weights on an LT. Good way to tear it up. (Trans just isn't heavy enough.) Plus, that blade isn't going to hack being beat around too much.
I'm wouldn't think the plastic weights from Sears or home depot would hurt. Theyed only add about 50lbs to it, heck I'm not telling how much I Add when I climb on! Lol
What model LT are you using?
If you have the accessories booklet that came with said model tractor, and weights were offered, or a push blade I wouldn't worry about it. But use your head and proceed with caution. As others mentioned, do your snow removal before the snow get's the upper hand. And I wouldn't be jackin forward and back with a set of chains either. Have fun, and let's see some pictures with it's winter cloths....
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
My carrot head"Bota" LT use to plow snow with plastic wheel weight and chains in his other "Life" before I purchase the poor thing from those evil "Gobernement" workers .
The G730 HG tranny and the "Bota" frame manage to survive but the OEM crappy engine did not.It's actually a very solid LT! (Over 600lbs) I think CC LT with his 9 gauge frame can deal with plowing but only if his tranny is up to the task. Hydro enemy is heat but in winter cooling is not a problem.
But we don't know which LT he has. It may not be a hydro. It may be the one with the friction drive tranny, which won't hack much abuse. Need to know the model of the tractor......
Agree, I don't even know what those new LT CC got, The only LT I dare to look at got 23" inch wheel under. (GTX1052)
Thread Tools | |
Display Modes | |
