Greg Rozar AKA- CubDieselFan
Old 07-23-2019, 05:45 AM
2wheelsadam 2wheelsadam is offline
Default Crankshaft rebalancing?
Installing new aftermarket piston and rod into k341. Does crank have to be rebalanced? Someone told me they do because that's why kohlers broke connecting rods? Whats your knowledge and experience on this? Thanks
Old 07-23-2019, 07:06 AM
I can't say that I have heard of re-balancing as a standard procedure. Unless there was some major event, I would say you are fine.
The Kohler aluminum connecting rods break due to "metal fatigue" after being in service for 40 yrs. Longevity has a lot to do with the service, conditions, and maintenance life of the engine.
Roland Bedell
Buy: Made in the USA
Old 07-23-2019, 07:57 AM
To elaborate on what Roland said.
Most replacement rods/pistons try to maintain factory weight.
As these little engines see only 36-4000 rpm's
most, cannot tell any difference if there was a slight difference in replacement rod/piston weight.
Now if the overbore was +.125 or a different material say like from old skool cast iron pistons to aluminum pistons, then there would be a benefit to re balancing of the rotating mass, or if it is going to see 7 or 8000 rpm's then it would be recommended, to keep all parts inside the block, as intended.
An example would be the once popular John Deere 2 cylinder "johnny poppers"
The early ones used cast iron pistons, later models went to aluminum pistons
and they easily were bored 1/8" oversize.
Those 2 pistons were big @ 5-1/2" and more, diameter (coffee can size)
But they didn't really need a re balance as the rated rpm's were approx 1200.
If one were to investigate the rod failures in the Kohler cast iron singles,
They would see most are from lube failure, (poor maint/ periodic oil changes) abuse, like over-speed.
Or continuing to operate with obvious knocking sound till destruction internally.
Occasionally a rod will fail just because it had a structural imperfection but it is an exception rather than the rule.
Ya I know,
too much info.
Old 07-23-2019, 08:28 AM
Default thanks
Ok thanks guys for the quick replies. That's kind of what I thought but you never know so better off to ask.
