3205 won’t stay running until REALLY warmed up
Hi,
It seemed to get it moving “ok” and now another problem. It starts right up with full choke, runs for a few like crap, and then dies. I screwed with the choke, and I can keep it running for a bit then dies. It starts right up again full choke. After about 15 minutes re-starting, suddenly runs fine no choke, even idles fine. For sure seems like a fuel problem. Any ideas? Thanks in advance for any advice! |
intake leak. Maybe the gasket, or crack somewhere that expands with enough heat.
I had a similar problem and my fuel pump had failed. It made noise but pumped almost nothing. I bought a pump on the "bay" for 12 dollars and its been fine ever since. pull your fuel line to the carb and see what comes out if anything with the key in run. my pump used to just tick at a constant rate but the new one starts fast then slows as the pressure builds up. (2-3 seconds)
Winter is iced up! Water in fuel?
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Thanks for the replies! Low 40’s so probably not ice. I’ll look into the other things (fuel pump is easiest).
Does this engine have the plastic intake?
I assume under the carb? I’ll take a look tomorrow.
thanks |
I looked it up. It is aluminum, which is good. I am thinking intake gasket, like that was mentioned before.
Thanks for looking that up! Seems to make sense .. I’ll get a intake gasket. Thanks!
I have a very similar problem with my 3165 with the Briggs engine. It starts right up with some choke. Then back the choke off and slightly increase the throttle. When I try to lift the blower it will kill. I can't even drive forward 5 feet to get the exhaust out of the garage without killing it a time or two. Once I do get it out of the garage, I walk away for a bit. I don't even try to use the blower the first 5 minutes. After that, it works just fine. I haven't really investigated yet. I just roll with it.
Mark from Minnesota 3165 with CC Snow Blower, Front blade, Sims Cab 3185 with 3pt hitch, it runs now. But not well. 48in and 52in mower decks 2185 with mower from my dad when I have a project for it. Massey Ferguson Model 70 corn planter. CC yard cart |
Thread Tools | |
Display Modes | |
