Greg Rozar AKA- CubDieselFan
Old 12-29-2020, 05:18 PM
Kris Brown's Avatar
Kris Brown Kris Brown is offline
Default 1811 blowing fuse
So I picked up an 1811 about a month ago and everything worked good when I got it but then a couple of snows ago I went to run the snowthrower and when I turned on the PTO switch it blew the fuse. I replaced the key switch and the PTO switch and it still is blowing it. PTO works with a jumper wire and rocker switch I made up for temporary use. Has anyone else had this problem before? I know wiring and can do wiring, just curious to see if it might be something simple so I'm not chasing wires cause everybody knows that's super fun. Thanks in advance
Kris
63 CC Original w/ 38” deck and front plow
72 129 50” deck, 42” blade
73 86 42” deck, 42” blade
84 CC 680 w/50” deck and 42" plow
89 CC 1811 46GT" deck,QA42A, 38" IH 1A tiller, Brinley-Hardy plow x2
1982 Gilson Lawn Tractor with 38" deck
Old 12-29-2020, 05:39 PM
Sounds like you have a shorted wire (Black) from the "B" Terminal on the PTO switch to the PTO Molex Plug. Take a DVM and trace it down and fix the short.
Roland Bedell
Buy: Made in the USA
Old 12-29-2020, 07:36 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
You could also disconnect the connector going to the coil on the PTO clutch, measure what to get for resistance across the leads, THEN measure the leads - one at a time to ground. I had a 782 that was doing the same thing once. I found 1 lead that practically had 0 zero ohms to ground while the other lead had a resistance of the coil winding to ground. Since I had a driveway to clear snow from, I needed to get it running if possible. I ended up swapping the positions of the PTO coil wires in the connector. I figured if one wire gets 12V and the other gets ground, I might as well connect it so ground gets applied to the grounded wire and 12V to the other. If it worked (and it did), I was able to run it clear the drive and replace it once it came in.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 12-29-2020, 08:14 PM
Kris Brown's Avatar
Well I was just outside messing with it and I found two things, a previous owner had hard wired the seat switch and bare terminals were touching the battery box so I taped them for now and the other was that the terminals on the reverse relay were pretty cruddy so I cleaned them up and i put in a new fuse turned the key on hit the PTO switch and it didn't blow the fuse. But thank you for the possible solutions
Kris
Old 12-30-2020, 09:37 AM
Sounds like you solved your problem, all you need is snow...
Up to 530 and counting...
Old 12-30-2020, 10:00 AM
RLause's Avatar
RLause RLause is offline
My old boss said that 1/2 the problems could be fixed with your eyes. I've found that to be true.
Richard
Old 12-30-2020, 11:24 AM
ironman's Avatar
ironman ironman is offline
That's what Ray said....
