Greg Rozar AKA- CubDieselFan
Old 06-25-2018, 05:40 PM
kingofnapier kingofnapier is offline
Default Front pulley rubs against deck when hitting bumps.
How do I resolve on an LT1050?
Old 06-25-2018, 05:58 PM
Tighten things up.
You obviously have something very loose or maybe even the deck is cracked around that pulley allowing movement or both.
Old 06-25-2018, 06:11 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Maybe it is what ever you fixed/changed or bypassed to get it running?
Old 06-25-2018, 10:35 PM
dale c. dale c. is offline
right deck ? ,pto clutch changed at some time ? ..you said when you hit bumps . are they big enough that the deck is getting hung up on them ? and forcing the deck up higher than it's supposed to go ?
Old 06-26-2018, 06:52 AM
cooperino's Avatar
That pulley looks awfully low. Like wrong pulley or loose bolt and slide down and near ready to fly off. I would give that a tap and put a socket on the bolt just to check. Does not sound like this is a new deck to th op. So something changed mid mow sounds like.
Tires flat?? Lol
