CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
OCC Archives
Old 01-08-2022, 11:08 PM
Farmall450's Avatar
Originally Posted by 1811woody View Post
Thanks Sam Il'l look into that thought, I have to add though on my 1811 it seemed to be slow so maybe a little more speed is what it needs? Lol I wonder what rpm its rated for?
A gambling man would just throttle down a lil.
The older pulley is 4.5" or something in that range. Search the forum, it'll come up.
EDIT: 4.5 to 6 was the pulley change. See below for ratio difference.
https://www.onlycubcadets.net/forum/...ad.php?t=50926
Cub Cadet 1282 | 44C Deck, Chains, Snow/Dirt Blade, IHC Cast Weights, 020" Over K301
Cub Cadet 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S
Cub Cadet 2182 | 48 GT Deck, Plastic Shell Rear Weights, 21HP Kubota 3 Cylinder Gas
Cub Cadet 1811 | 46 GT Deck, #450 2 Stage Snowblower, Chains, IHC Cast Weights, M18 Magnum
Old 01-09-2022, 08:53 AM
R Bedell's Avatar
R Bedell R Bedell is online now
It is always a good policy to use the right attachment for the right tractor for optimum performance.
Mix matching usually requires modification, fabrication, premature wear, and less the normal performance.
Roland Bedell
CC Models: 100, 105, 129, 1450, & 784
Buy: Made in the USA
Old 01-09-2022, 11:22 AM
Farmall450's Avatar
Yeah, the engineers at CC/IHC knew what they were doing.
Does anyone know why industry went to the larger PTO pulley? Just couldn't get enough blade speed?
Old 01-15-2022, 10:42 AM
Larger pulleys have less slip and greater belt life
--A snowball effect in the correct direction!! (no pun intended)
Best situation is to match pulley's to equipment.
Throttling down decreases H.P. available to do work.
Now that said, small differences in diameters usually is not noticable,
but one could try changing the driven pulley a bit and try it under actual use conditions
Ideally, an engine would be at full governed rpm's, while the thrower would have a full mouth of snow, going at a comfortable foward speed.
but so many variables are to be considered, so the engineers try to achieve a happy medium.
Pulleys are relatively inexpensive at surplus places/ 'net etc.
of course a belt length change will have to be considered is some cases.
A higher speed auger is ideal in light fluffy snow, but drags the engine down in sloppy wet chit.
I went to one more tooth on the jack shaft to increase RPM of the auger/paddles as I have a stout M-18 to power it.
I only mention that as there are more than one way to achieve
Rpm changes.
You could go 1 tooth less to decrease final auger rpm.
You would have to do the math to see what your final rpm's are.
One might hang a Qa on a say 14 or 16 hp GT, and find in heavy stuff it is slow going and/or you will run out of HP and clog your chute.
Just something to think of on a sleepless night.
If I were doing your installation, I would match the gearbox pulley to that of the drive PTO of the engine.
I changed the sprocket, only because it was badly worn and I thought if I was going to change it, why not see if a bit more Rpm's would be helpful.
Old 01-17-2022, 11:56 AM
Billy-O's Avatar
Billy-O Billy-O is online now
Rpm changes.
Maybe it not so big a deal but do consider throttling down means change in feed rate....how fast the tractor moves.
Plow blade
#2 Cart
QA36 snowthower
Copyright ©2000 - 2022, vBulletin Solutions Inc.
