Project 1811......thinning the herd
I picked this 1811 with a blown head gasket in 2013. I drove it off the trailer and into the ole chicken barn. There it sat until 2017 and I pulled it outside when I tore the chicken barn down.
1811-1.jpg Now it's time to thin the herd! I pulled it into the shop a week ago to get it running and found this this thing is caked in grease, grime and oil everywhere. I pulled the engine and the rear cover to drain the Hy-Tran. Then it was pushed outside and pressure washed. IMG-6810(1).jpgIMG-6818.jpg I wonder why it blew a head gasket? IMG-6892.jpgIMG-6831.jpg Looks like a remote oil line is leaking also so I posted a ? in the Kohler Engine Section. https://www.onlycubcadets.net/forum/...ad.php?t=61918 Yesterday I got the engine and tins cleaned up, oil drained and ordered some gaskets to put it back together to see how well it will run. I'll keep y'all posted on the next step.
I always feel good for the tractor when they get all cleaned up.
They do have feelings don't they? Ken |
Is that magic dust to prevent rust?
Hard to believe they survive that kind of cooling blockage, but they do.
I would change the oil seal behind the Stator while your there. My 1641 looked like that when I took the flywheel off.
Cannon |
Yes sir Cannon. Both the front and rear seals will be changed, valves checked and the PTO bearing will be replaced while the engine is out.
Starter could use a look see...
Yep, it’s already pulled off and it will be opened up and will be cleaned and lubed before it goes back on.
I need to check the rockshaft and make sure it’s not siezed up too.
Thinning the herd...
Never seen anyone turn their tractor on its side before to power wash it. Probably was the best way to get rid of all the grime on it though...
Yeah, I might have to use that one in the future!
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
