CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 01-24-2020, 12:22 AM
guido guido is offline
Default Working with acrylic
The windows on my Windbreaker are shredded. I have been thinking that if I can route a flute in the edge of some .220" acrylic sheet that it might just snap into the wire window frame without the need of any fasteners.
Made a crude cutter for the router table. If I can keep the tool speed down and the material feed up it may just work without turning this into a molten mess.
If anyone has some tips in working with this material please chime in.
Thx
Alan
Basket Cases: 129, 1450 sold, 1650
125: 48" Mower Deck, Windbreaker Cab
127: 3 turn steering gear, Spring Assist, Sleeve Hitch, 48" Mower Deck, Dozer Blade
147: 3 turn steering gear, Spring Assist, QA36a w/Xtreme Motorworks Wings
Old 01-24-2020, 08:31 PM
john hall's Avatar
I hate machining acrylic. Its very brittle and will break/crack/melt. Is using Lexan (polycarbonate) an option? If you must use acrylic, keep the tool and workpiece clamped securely. The tool needs to be sharp, but not so much it grabs the workpiece. Not sure if what you are trying will work at all on a router table--fast RPM, no coolant, the workpiece is not clamped. Good Luck.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-24-2020, 11:22 PM
Thx for the input John.
I know what you are meaning about work holding. No way to hold the piece down for this operation. I'll just have to take multiple light passes and hope for the best. I read somewhere than freezing the material may help.
I may have to rethink my cutter. My original thoughts wear aimed at chip evacuation.
Alan
Old 01-27-2020, 09:27 PM
One down. One to go. Had to really turn down the router and feed it slow. Still need to cut out for the hinges and come up with some sort of retainer clips just in case. Don't want these widows popping out at the most inopportune time.
Alan
Old 01-27-2020, 10:07 PM
Acrylic is brittle, be careful drilling holes near edges.
When the drill punches through, it grabs and tends to spall or bust out.
When building guarding, we went to lexan (polycarbonate) as it will cut on the shear and bend in the brake as well as drill/tap without breaking.
As far as edges, we rounded them with a rasp file and hit the edges quickly with the acetylene oxy torch with neutral flame, making them smooth like they were never cut and clear, giving a nice looking job.
It takes a little practice to get it right, but worth the effort.
---just my experience
Old 01-28-2020, 08:59 AM
Thanks George, for the words of caution and your insight on this material. I have used it to make guards, covers, and enclosures in the past. Just never did any edge work with it until now.
Did I really need to flute the edge for this? Probably not. But it will stay in place better with fewer fasteners.
Alan
Old 02-12-2020, 08:58 PM
That came out great! As a 30+ year auto glass guy, acrylic is a pain in the ass to work with.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 02-13-2020, 11:14 AM
Thx Randy,
It was tedious to say the least.
Alan
Thread Tools
Display Modes
