Reccomend replacing lug bolts with wheel studs and nuts?
I have a Cub Cadet Original, and I bought dual wheel adapters for it. The original lugs are too short, and they won't go through the wheel. I tried finding lug bolts that would be the correct size but I can't find any. Should I try replacing the lug bolts with wheel studs and lug nuts so the wheel adapters can reach? It might even be easier to replace the wheel and tires too.
Do you think I could use regular bolts with lug nuts as opposed to wheel studs since I have some of those lying around?
I have used regular 7/16-20 bolts, screwed in from the back. But I had to grind just a little under the head because the threads didn't go completely to the head. I am talking just something like 1/16" or so. Look at your bolts and you will see what I mean. Other than that,they worked fine. I have also used 7/16-20 all-thread/threaded rod with a thin jam nut in the back behind the flange. I found the 7/16-20 all-thread at Fastenal.
Cub Cadet 100 "Super" (red) show tractor Cub Cadet 100 show tractor. Cub Cadet 100 worker Cub Cadet 106 refurbished/modified (red/white) Cub Cadet 128 "refurbished" Cub Cadet 1450 my dedicated mowing tractor Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper. 100 w/pan seat and 3 point hitch |
Or to keep from grinding, put a washer under the head. The bolt method won't work on later tractors with disc brakes.
I put studs on a 149 I used to own. Got the studs, jam nuts and lug nuts from McMaster Carr
94846A520 jam nuts 98750A474 Studs 4991T964 lug nuts
Those make so much more sense than the bolts that IH used.
Daniel G. . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
I'm thinking of doing this too. I am assuming the jam nuts are only used on the back side of the flange so the rim sits properly?
1964 Model 70 that Dad bought new. Lights, fenders, creeper, 38 inch deck, Brinly plow, sleeve hitch, and lift assist. |
Thread Tools | |
Display Modes | |
