Greg Rozar AKA- CubDieselFan
Old 12-09-2018, 08:55 PM
Originally Posted by Billy-O View Post
I agree with the others......chains on the turf make you go better.
Agree, loaded ( or weights ) turfs with chains ( 2 link is better than 4 ) and skinnies up front steer better too.
Old 12-09-2018, 10:24 PM
MiniXP MiniXP is offline
Anyone have any recommendations on some new turfs to buy? I'm in NC, which it looks like OP is too, so was out plowing the same wet snow. Got over a foot near me though.
I have chains on some ancient turf tires, planning to buy some new ones as the rubber on them is so hard they get no traction. Had to hit the snow with a running start to get anywhere today. I dont currently have much weight on the back either, just bolted some old brake rotors to the rear which helped slightly. Will probably fluid fill the tires when I get new ones.
Old 12-09-2018, 10:38 PM
johncub7172's Avatar
Look for a turf tire in the size you need, any will do if you don't mind. I got a new set of the 4 link "V" bar chains, which are a little less expensive than the 2 link "V" bar. I don't mind the 4 link for as much as I need to run them. You're better off with a good set of chains before any weight. A good weight solution is going to wmart and buying 6-7 10# cast iron weight lifting weights, and with a small, thick piece of steel bolted to the fixed drawbar, you can bolt the whole stack of weights there. If I ever do fluid fill my tires, I'll use tubes in the tires first! There is no substitute for chains on ice.
Old 12-10-2018, 08:33 AM
lawn mower handles great
Lawn mower????
Old 12-10-2018, 09:06 AM
john hall's Avatar
Lawn mower????
Yep, you know me, if it says Cadet its a lawn mower. Would you believe this REALLY pisses off the FB crowd.
Actually this one is turning out to be a toy that I hope will save me from having to put a scrape blade on a tractor for 5 minute jobs. Have used it a couple times for small jobs so far and am impressed since I got enough traction.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 12-10-2018, 10:10 AM
sorner's Avatar
sorner sorner is offline
Looks good to me John. Turfs with chains and weight seems to do better for me plowing and blowing. I have loaded ags on my Jake with a snow blade, and in the summer I plow garden with it, and it does pretty good, but it will spin in snow and ice where my turfs and chains won't. The filled ags are really good in the dirt though. I have trouble keeping the front wheels on the ground.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 12-10-2018, 09:02 PM
Grew up with Dads 125 that rarely had the mower deck off. (used a Farmall H for snow removal) so we always called it 'the lawn mower.'
Old 12-10-2018, 10:20 PM
Farmall450's Avatar
IMO chains on turf tires do a lot better in snow. Same with big tractors - ag tires don't cut it. R4s are the worst
