Snow removal--first attempt
OK my Yankee and Mid-western friends, grade my first efforts on moving snow with a Cadet. So we have 9" of snow that will not hold you up (no good for sledding), you sink pretty deep in it. I used the 124 to clear in front of the garage (it never melts there). Now I did not intend to clear it all the way down to the concrete as we are getting sleet and freezing rain now--figured something not so tough under the bottom would be easier to scrape away. Anyway, lawn mower handles great on the concrete, pretty much a fast idle in low gear. I had trouble trying to get to the concrete while driving on gravel, one wheel would break through to the ground. I also had a little trouble with this when backing up on the concrete, got it "stuck" twice. So, is it the conditions or do I just need chains? I'm running loaded skinny ags with 160lbs of weights on the drawbar and my 200lb in the seat.
Wet snow is the hardest to plow, I have chains and 200lbs of weights and still spin the tires (on gravel), but that is at the end when I am starting to pile it up. I run 8.50 tires with 2 link chains.
N.Y. Yankee hint... Pack the snow before you go sledding, dead bodies work well when rolled up in a carpet and rolled down a hill.
The year we got 21" I packed my driveway with a farm tractor. BIG MISTAKE. 2wd truck and a Ford Thunderbird were not enjoying it for a week.
Always so much easier when the ground is froze up.
A set of 10.50 turf tires and chains will run circles around those little AGs..
I used to use basically run the same tractor with a 54 inch blade,, the tractor never stopped, because of spinning,, now,, I gotta say, I did not want the tractor to spin,, that would mess up everything,, so I worked hard at driving the tractor so the tires did not spin,, Run the tractor in the highest gear possible,, I would rather slip the clutch in high gear than spin the tires,,, |
I load the tires, use 2 link chains on turf tires and have small wheel weights.
no problem going where I want up to 12" with the thrower. Any more than that, I am careful to make sure the thrower is ahead of the direction of travel so as to lower the depth of the snow. |
Agree with CADplans. Ags are for mud in the garden not plowing snow. Turf or atv style tires loaded, with chains and weights if needed is the way to go.
I agree with the others......chains on the turf make you go better.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Well, at least 5 of you guys are saying loaded turfs with chains. Hmmm, wonder what we have in the corn crib? No chains, but maybe a set of old turfs already mounted. Think there is a set here off a 110 Deere.
So, since I already have the ags, would they be better for summertime, mud, grass, loose/deep gravels as opposed to loaded and chained turfs? I will admit, those ags will flat out dig now with all the weight--seems to be the problem with the snow, they want to claw through it!
Try what we find works, if you find differently, you can always go back what you like.
Do get the 2 link chains rather than 4 link. |
