Greg Rozar AKA- CubDieselFan
Old 11-28-2018, 10:22 PM
Camarors8992 Camarors8992 is offline
He also should get a screen for the flywheel
Are there vendors that can still source this part?
Old 11-28-2018, 10:24 PM
He has that adapter, the drive shaft for a 2072 is about 2" shorter than the shaft for a 2084. He has 3 options, a spacer, convert to the CV style shaft from a 2084 or 2284 or have Jeff make him a longer shaft.
Where could I buy a spacer? I don’t think I’ll have much luck finding a driveshaft from a 2084 or 2284 as they are sought after machines.
Here’s a better angle of the the connection in place now.
File Type: jpg 818094FE-B4C2-42E4-8761-D990FCAE3576.jpg (15.8 KB, 119 views)
Old 11-29-2018, 06:33 AM
ccpullin ccpullin is offline
Originally Posted by Camarors8992 View Post
I had never heard of a trunnion before your post, but I did some reading and I think I now have a decent understanding of my problem. Mine is Worn and sloppy so I’ll have to bring it to work and fire up the welder.
Thnk you for you me input!
If yo are going to weld it be sure and place the ground clamp on the part you are welding it self, or you will ruin the needle bearings on trunnion shaft and possibly the entire hydro!
Old 11-29-2018, 06:44 AM
Water pump to fan spacer for older chevy/ford motor. They come in all different thicknesses available at NAPA, Jeg's, Summit... Use locktite on the bolts! I have done this before when converting from a magnum to a command with no issues. You can convert to a cv shaft although even with used parts you will drop $$$ in all the parts needed (cv's, shaft, fan, bolts, and hydro flange). You will also have to drill/tap the hydro input shaft for flange retaining bolt with cv conversion.
Old 11-29-2018, 06:48 AM
If it was my tractor I would call the sponsors at the top of the page and see if they have a 2084 or 2284 complete drive shaft. You can have Jeff make you a new longer shaft. He could make you a spacer.
Old 11-29-2018, 10:02 AM
I would not run that engine anymore as it is ready to create more problems for you.
Up to 530 and counting...
Old 11-29-2018, 10:06 AM
Here is another alternative from Midwest Super Cub. It is the drive adapter for a Kohler Command installed in a Cub. Less than $40 and your done!
https://mwsc.co/products/command-clutch-hub
Old 11-29-2018, 12:02 PM
Done deal. I like simple. Do I keep those rubber spacers in there?
Old 11-29-2018, 12:05 PM
Here’s my trunnion issue. As you can see, every part of it is worn. Might be better to replace with new? If available of course. Also, I was going to drop the transaxle to work on the trunnion just for ease of access but one hydraulic line isn’t having it.
I tried uploadinf a video but it wouldn’t let me.
Old 11-29-2018, 12:34 PM
Yes, this replaces the hub presently bolted on the engine flywheel and the flange with the bushing in it bolts to this. I want to mention this engine was never in production of that model tractor. With that said, hopefully the person that installed the engine slid it back far enough when they re-drilled and mounted the engine. You are dealing with a fuel tank in your tractor where as a battery was mounted in the later tractors with a command. You may have to re-drill and slide the engine back a little bit if this spacer is not wide enough.
