Cub Cadet 782D
I have a Cub cadet 782D I need support fan. P/N 759-3201 It is NLA from cub cadet would anyone know where i can get a used or NOS?
The bearings are replaceable if that is what’s wrong.
I need the housing. It cracked.
I'd just spin up a new one on the lathe and make or reuse the existing bracket if it looks as pictured.
I had that housing crack off on my 782D, lucky the fan only made a small impression on the radiator when it went and no holes. There was a service advisory on that part failing and a service kit was put out on it. The new bracket was a one piece cast aluminum part. Have you tried any of the sponsors to see if they have any on hand?
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
I welded mine. Not pretty and the angle is a little off but it works. I couldn't find one either.
Did you check with the Sponsors listed at the top of the page...???
I have emailed all of the sponsors and am awaiting a reply. I wish i did have a lathe
If you strike out, contact "parts by Jeff" @ the top of the page, he might
be able or willing to make it. Can you snap a couple of pix of it and post?? |
Maybe Kubota still has it available.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Thread Tools | |
Display Modes | |
