Greg Rozar AKA- CubDieselFan
Old 11-02-2018, 01:25 PM
bultaco4ever bultaco4ever is offline
Default Newbie with model 108
Hello...I just got a Cub Cadet 108 tractor and it isn't running. I pulled the spark plug and checked for spark....yes it has spark. I squirted in a small amount of gas in the spark plug hole, reinstalled the plug and she fires and runs briefly.
So, I assumed fuel starvation. Took the tank off and cleaned the petcock screen (it was plugged good). I bought a new float bowl rebuild kit and cleaned the carb with carb spray really well.
I unscrewed the needle jet and I wonder what this need jet adjusts? Do I bottom it out and back off 3 or 4 turns?
Old 11-02-2018, 02:29 PM
Merk Merk is offline
First
There is a service manual in the technical section that will very helpful in getting your 108 running.
Link to the manual you need:
https://www.onlycubcadets.net/forum/...ead.php?t=4646
Feel free to ask any question.....There is such thing as a dumb question in my book.
Project Uncle Dick
Cub Cadet 70
Old 11-02-2018, 03:49 PM
Bamafan's Avatar
Bamafan Bamafan is offline
Welcome to OCC, looks like you're on the right path to getting it running.
Larry
Old 11-02-2018, 04:19 PM
cooperino's Avatar
Welcome!
Sounds like your talking about the mixture screw. I start out with 1.5 turns from closed. Then I adjust according once it will idle. If you cant get it to idle then you likely need to clean carb better.
Old 11-02-2018, 05:03 PM
DeltaCub's Avatar
DeltaCub DeltaCub is online now
Originally Posted by cooperino View Post
Welcome!
The idle mixture screw initial adjustment is 1.5 turns as you posted. The high speed is the the long one going straight down...that initial adjustment is 2.5 turns out from being lightly seated. Ideally, adjust your spark timing...get that right first...it can be done without running the engine. Set your initial carb adjustments so the engine will run. Once it is up to operating temperature and using fresh fuel...adjust the settings to "tune it".
Queen Of The Quietlines!
