Greg Rozar AKA- CubDieselFan
Old 10-09-2018, 08:05 AM
brudder brudder is offline
Default For those who have added dual hydraulics to your Cyclops
What did you use for a bulkhead fitting if you didn't use the Cub quick connects? I haven't found anything that would seem to work as well as the Cub fitting with the retaining ring yet.
Old 10-09-2018, 08:48 AM
The IH/Cub Cadet couplers were made by Parker up to s/n 800,000. You can use: SM-251-4FP
Roland Bedell
Buy: Made in the USA
Old 10-09-2018, 10:50 PM
Thank you Roland. I would also be open to using a standard ag coupling and switching out the end on my blade if that would be a better long term route that wouldn't lock me in to the expensive Cub or Parker specific fittings. I'm just not sure how to actually lock the coupling into the holes in the frame.
Old 10-10-2018, 05:43 AM
You can buy the Parker fittings online or at any Hydraulic Shop.
Roland Bedell
Old 10-10-2018, 05:52 AM
Would these be the ones?
https://www.amazon.com/Parker-Hannif.../dp/B01BY6U1V6
And these for the hoses?
https://www.amazon.com/Parker-Hannif.../dp/B01BY6QP0C
Old 10-10-2018, 01:29 PM
Thanks guys. I ordered two of them this morning. Pictures for that part number vary on different sites so I'm not sure if they will accept a snap ring to hold them into the frame or not. I'll report back what I find out.
Old 10-10-2018, 03:54 PM
DieselDoctor's Avatar
If you ordered Parker fittings using the Parker part number , it will have a snap ring grove. I've purchased several.
Old 11-04-2018, 08:19 AM
CNeubauer CNeubauer is offline
When I did my 2182 two years ago I couldn't get a snap ring to work, the frame was too thick for the new couplers so I got some 7/8" collars with set screws and slid them on the back of the coupler to hold them in place.
Old 11-19-2018, 11:00 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
That beats a hose clamp all to hell!
1- 1200 in pieces
1- 1864 in pieces
Old 12-05-2018, 07:35 PM
Thanks to everyone who provided input on this thread. As Diesel Doctor said, the Parker fittings came with the snap ring and fit perfectly. This was a pretty straightforward project. The most challenging part for me was extending the hard line back to the hydro pump. I had a rusty line so I cut out the rusty part of the line since I needed to extend it anyway. I flared the ends and used standard 3/8" brake line as a replacement. I bought used lines for the lift cylinder and 18" hoses to go to the front outlets.
