Greg Rozar AKA- CubDieselFan
Old 08-28-2018, 08:33 AM
RT0426 RT0426 is offline
Question BT from upstate NY
just joined but have been perusing the site for a few weeks now since I purchased a 1971 cub cadet model 109. Love it. Has a Kohler K301 engine in it so basically got transformed into a model 129. Runs great just needs some clean up. The mule drive belt is quite worn and has started jumping off the mover deck fly wheel. the belt on the unit is 1/2 inch by 81 inch but what I have found is that it is supposed to be a 3/8 inch by 80 inch belt. Would that be why it is jumping off? Look forward to restoring this tank.
Old 08-28-2018, 08:41 AM
cooperino's Avatar
Welcome! Love pictures here BTW.. You stated the belt is worn and possibly wrong belt. That in itself could be the reason its "jumping off" or, Your tension could be wrong or other issues in mule drive. But if you suspect your belt is wrong I would start there. Also, measure your old belt. If its worn it could also have stretched.
Old 08-28-2018, 08:52 AM
The mower deck doesn't have a fly wheel, it has a pulley. Big difference.
You don't say what deck you have but yes, it likely takes the 3/8"X80" belt. Need to know what deck you have to be sure though. An incorrect belt can make it jump off the pulleys, yes. So can incorrect mule drive pulleys, incorrect deck adjustment, bent components, and several other things.
Old 08-28-2018, 09:26 AM
It is 42 inch deck with three blades. No bent components, mule drive pulleys are original and appear to work fine as does the tensioning spring on the one mule drive pulley. Deck does appear to tilt forward somewhat so I am thinking that between the wrong/old belt and the fact the deck is tipped forward a small amount that might be the reason. I will find out this weekend when I can work on it again.
