Gifted a CC100 with K341?
I was gifted a CC100 with a #1 tiller. I've no other historical data available to me on her prior life.
She seems to have been stored inside, and it's clear she hasn't run in a while....based on the layers of dust. She turns over easy with the starter and by hand. Missing parts include coil, condenser, points. Carb is dangling by one bolt. I expected her to have a 10hp K241. But when I pulled the head to inspect the cylinder I judged the bore to be significantly larger than the bore on my CC108. Very little carbon build up and head gasket seems intact. Yep, bore is 3.760. Seems that is a K341. The engine appears to be very similar in shape to the engine on my CC149. There are no ID plates/tags on the shroud. I'm not sure what a notched narrow frame should look like. Or for that matter what an OEM frame would look like. I'm guessing this is a rebuild installed as an "upgrade" as the head bolts had Grade 8 marks on them. I'd like to get her going and plan to work on her this winter in time for spring garden activities. Any suggestions on how I can confirm she is a K341 16hp on a CC100? I'd like to get some parts ordered. Thanks, Daryl MN |
