#81
Master fabricator !!! Great build !!
#82
Besides the blade circle and walking beam suspension for this machine, I want to build a rear finish mower for my 128 rear PTO Cub.
That is simply amazing. Something to be very proud of. It looks like it will be just the thing for maintaining your gravel driveways. Thanks for posting.
Tom |
#84
I have some grader time, and really enjoyed that work. Really like what you've done so far.
Steve |
#85
Started working again on the grader. I've added the hydraulic driven blade circle and it works fine. Next task it to install the locking lug that will remove and insert the locking pin to prevent overloading the hydraulic drive and stripping gear teeth.
Here's a short video of the blade motion. https://youtu.be/IFepW2uEUfI Here's a longer video of the grader in action, recorded before the blade circle was installed. https://youtu.be/lveiY__nZis
Totally Awesome!
Alan Basket Cases: 129, 1450 sold, 1650 125: 48" Mower Deck, Windbreaker Cab 127: 3 turn steering gear, Spring Assist, Sleeve Hitch, 48" Mower Deck, Dozer Blade 147: 3 turn steering gear, Spring Assist, QA36a w/Xtreme Motorworks Wings |
#87
Very nice job on that grader project.
#88
A labor of love, with attention to detail.
Very nice "sir" Carry on. |
#89
Very neat project. Will be fun to use her on the driveway some.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
#90
Keep us posted
'70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
