Greg Rozar AKA- CubDieselFan
Old 09-20-2018, 04:31 PM
Default Mechanic in a can PS fix
Mechanic in a can PS fix. OK let the negative comments begin. Here's the deal the power steering on my 1864/2264 has been getting sloppy to the point that I was planning on pulling it apart and doing the reseal routine to it. Just for the hell of it I bought a bottle of Bars Leak rear main seal repair and dumped it in the tranny. Cost me a whole $8.94. Figured for that huge sum of money what have I got to loose. Well damn after about 30 mins mowing with it I noticed it was getting better, by the time I was done about 3 hours it feels as good as new and the howl is gone. It claims to swell seals so I figured the PS system in these things is nothing but a bunch of O-Rings. Am I recommending this, no I'm going telling you what I did. Now for a long term test to see how it holds up or if it causes any problems.
Old 09-20-2018, 04:36 PM
Know you for as long as I have, I'll say......I believe you Brother Sam.
Roland Bedell
Buy: Made in the USA
Old 09-20-2018, 05:00 PM
Now the other question. Most transmission leaks are the infamous cork gasket. Would this swell that as well and seal it off or will it only work on rubber seals. I think we need another volunteer.
I’m curious Sam. Did you by any chance smell it? Does it smell like it has brake fluid in it?
PS before you get flamed and pissed off, might I recommend pepper in the radiator and banana peels in the differential?
Just kidding, good for you. I’m interested in the long term on this so hope it’s updated in a while!
Old 09-20-2018, 05:45 PM
cooperino's Avatar
I believe it for sure. It makes seals swell. That seals the leaks temporarily because it also softens the seals. Get away with it as long as you can. It works great in a pinch sometimes. I have had the same experience with it... now the other mechanic in a can for knocks lol.. not so much.
Old 09-20-2018, 06:35 PM
I didn't have any leaks to start with just the steering was getting crappy.
Old 09-20-2018, 06:49 PM
cooperino's Avatar
Hmmm. So more like a conditioner. We use to use lucas for that.
Old 09-20-2018, 06:55 PM
DieselDoctor's Avatar
Chemical compounds have come a long way in recent years. Each new idea needs to be evaluated with an open mind. The snake oils of years ago that were worthless have made us gun shy. Personally Sam, I believe your results and hope that you'll keep us posted as to how it lasts. Thanks for sharing.
Old 09-20-2018, 07:03 PM
cooperino's Avatar
Same here Sam. I didn't take what you said as an infomercial. If you say you saw positive results I'm sure you saw positive results.
Old 09-20-2018, 08:11 PM
It works it's ok, but I would like to hear a joke about a mechanic that came in a can.
Up to 530 and counting...
Old 09-20-2018, 08:22 PM
cooperino's Avatar
Im just gonna leave that one alone...
