Greg Rozar AKA- CubDieselFan
Old 12-14-2011, 05:33 PM
esarvey's Avatar
esarvey esarvey is offline
Default saga continues Fuel system!
Originally Posted by esarvey View Post
OK youngins, let's play, ball in my cort! ELECTRICAL: all componets,&wire together for build, picture has schematic (hidden, so feds who git U for removing tags from funiture, and smack U for dising OSHA !!!) & methos won't have a murmer, or fit! the wires to all components are 12ga. copper, the batt. +,- all 8-10 ga. will mechanicly place Batt. close to the starter solenoid, as possible. Electronic Physics rule, the lenght of a conductor & it's diameter/material, effect resistance to current flow!!! At higher frequencys,voltage can also run on the out side of the conductor, but thats mostly Microwave, which we will at a later time can query!!! (If I git the diesel moving that fast) I will use the oil switch sensor/light on dash,current amp.meter, remove HR. meter install temp. guage,using sensor on motor!
Radiator from a t1600 kubota tractor,solves cooling part of mechanical needs!! Tune in for further mid games, (old man who started building race cars at 16,verses young folk) !!! PS: today is my B-DAY it was 51 years ago I built my first race machine!!!!
Have 25' of 5/8 fuel hose, kubota prefuel, electric pump, Kubota filter/separator, groumet & elbow to add to 3 gallon tank for return from injector pump.
All components in place to begin build! I also have motor isolaters for mounting system. The hard part is about to start, mechanical adaptation to the 1862 frame/drive line/controls, will design & fabricate needed pieces! The modleing phase,helps the inovations flow. should be fun!!!
DaDuke of
2145,1864,1811,1810,1541,1330,1210,1020,1641,147,1 24,73, IH FARMALL CUB. 7254, 1863, IH 982
Old 12-14-2011, 06:06 PM
Oak Oak is online now
Happy B-day Earl! We are here to help. Your head elf in Pickens hi-jacked a 1512 smoker out of Georgia this year and David G's and my 882 are all the same setup you will need. If you need any pictures or measurements just let me know. I know on my 882 there is very little clearence from the steering column to the front coupler so be on the lookout there. Good luck and keep us posted.
Old 12-15-2011, 01:27 PM
esarvey's Avatar
Default Engine position
Thanks for the offer, but hard headed me, will install radiator to the front, their by ,no problem, steering box, but hydro valve hoses, might rerout them. won't be running PTO, pure plow machine!
DaDuke of
Old 12-15-2011, 04:37 PM
Donovan M.'s Avatar
yeah there is a fast race track here in Canadaguia.
Donovan:
62' Original-fenders
Old 12-15-2011, 06:46 PM
esarvey's Avatar
Default race track
Ya, I was on it in the sixteys,fastest dude was DUTCH HOAG, he ran supers at Shaingrala in Owego, sponser was Gennesee beer, Royal blue / gold cars!!!
DaDuke of
Old 12-15-2011, 09:46 PM
cub123's Avatar
cub123 cub123 is offline
Looks like its coming good Earl! It was great takling about cubs and looking at you collection the other day! Thanks for the much needed parts
Old 04-20-2012, 06:40 PM
esarvey's Avatar
Smile may the 12th plow day
Are U going to plow this May12th at Iona,ny??? I hope to be there!!
DaDuke of
Old 09-12-2012, 11:28 AM
dragoncub dragoncub is offline
Awesome build I'm in the process of putting a kubota d600 in a 782 ive got all the parts except for motor mounts and other brackets. I could fab up my own but if if I could get dimensions of the brackets it would make things alot more easy. Until then keep posting.
Old 01-02-2013, 10:00 PM
samckitt samckitt is offline
Can't wait to see more updates on this since I would like to repower with a diesel too.
Scot
Old 01-03-2013, 11:27 PM
Steve Fox Steve Fox is offline
Did you make it to Ionia, NY? I was there, I was riding the Wheel Horse B-145,
that was WH private labeling of the GE Electrak, it was also the only electric tractor there, I kind stood out! :-D Was that you I was talking too by the teck pit? Did you get the long distance award? BTW, Java, NY plow day is Sunday May 5th, Ionia, NY plow day is Saturday May 11 this year.
