Greg Rozar AKA- CubDieselFan
Old 09-19-2018, 10:23 AM
May as well go all the way to stupid.
https://www.youtube.com/watch?v=8LXFSLK3otM
Old 09-19-2018, 11:03 AM
Leadslingingdaddy's Avatar
He could have at least put a 54 inch deck on it!!!!
Old 09-19-2018, 07:09 PM
The purpose of the holes above the engine is to let out the excess air, and blow out extra dirt, from the filter housing. If you plug them off, you will create a problem. They need to be there. The fan pushes more air into the filter housing than the engine can use.... for good reason.
I have a question, on a QL it has the same type of air intake, where is the hole to let out the leaves?
Up to 530 and counting...
Old 09-19-2018, 10:41 PM
I wondered when someone would ask that.....
The QL was set up the same way, but they didn't put any holes in it to flush the dirt out. I do believe if you look though, the filter cap doesn't seat tight to the back. It can flush some dirt out. For the most part, the idea is the rotary screen on the flywheel will stop the big stuff, but we all know grass can still get through. Sometimes engineers get stuff right when they redesign. I like the later air filter base that can move air through it to help flush out debris.
