Greg Rozar AKA- CubDieselFan
Old 01-29-2012, 05:19 AM
nikster's Avatar
nikster nikster is offline
Default Cheap $ 6.00 added weight gizmo.
With my 280lbs. stout torso on my # 122 in snow & wheel weights w/chains I didn't want to go fancy with suitcase weights. So for $6.00 I just came up with some 3/4" pipe & 45lbs. of iron weights. The weights were so rusty & looked like crap. I brushed'em & sprayed some left over Bed Liner spray.
Not fancy but?
Old 01-29-2012, 09:10 AM
That needs to be braced to something so you don't bend the drawbar; you are applying a bending load to it that it is not designed for.
Old 01-29-2012, 09:14 AM
The weights look great nikster
That ought to give the 122 a little more bite
Old 01-29-2012, 11:08 AM
LarryW's Avatar
LarryW LarryW is offline
It looks like it might twist at the T fitting and maybe swivel at the hitch pin. If the hitch can take it, it looks like a good idea with maybe an added support.
Cub Cadet 147 2050041u340160
42" Mower Deck, Snow Thrower, Tire Chains and Weights, Rotary Tiller 1, Brinly Sleeve Hitch, Brinly 10" plow, Johnny Bucket Jr.,42" QA NF Dozer Blade.
Cub Cadet 1872 SGT
60" CCC deck.
Parts 129 future plans =ported pump for 147, cast iron rear for 1872,129 frame and steering axle= ?wagon?
Old 01-29-2012, 12:09 PM
nikster's Avatar
I snug it down REAL THIGHT with a lock washer & lock tite.
It looks a mile long but its only 8" away from the back of the hitch, 3/4" pipe should be enough to hold it since its flush on the underside & to the back of the hitch. I squirted in some lock tite on the threads.
We'll see?
Nik,
Old 01-29-2012, 12:21 PM
We'll see?
Nik,
Good idea on the Locktite. I was thinking tack weld or setscrew, but, Locktite is much better!!
Old 01-29-2012, 12:48 PM
That's roughly equivalent to 150# tongue weight of a trailer, which is really pushing it. If you go over bumps it may start drooping. Even a cable or something from the top of the vertical tube to the holes for the 3-point pivot pin on either side of the seat bracket would be enough to keep you from bending the hitch plate.
Old 01-29-2012, 02:29 PM
nikster's Avatar
Whoa dere? 150 lbs. Is alot. Didn't think of those #.
My drive is as flat as an bowling alley, so we shall see what happens after a few good runs?
If it holds fine, but then if it doesn't then I can see a extension to the seat bracket.
Thanks,
Nik,
Old 01-29-2012, 10:45 PM
westofb's Avatar
westofb westofb is offline
If you bend it, hit me up I got spares you can have for the the shipping! Good idea using what you had!
Jeff
Brookfield, MO
________________
Old 02-01-2012, 09:35 AM
nikster's Avatar
Thank you for the offer. But I have an extra hitch hook up just in case.
I took it for a test drive for about 15min., yesterday in the yard. I saw no problems with the set up. That's why I mounted the 3/4" pipie under the hitch. To create upward pressure on it. No movement of the pipe since it's got lock tite on all threads & & quite pleased with it.
Now if it would only snow? Last year at this time we had a blizzard & had OVER 24".
Nik,
