CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 11-16-2018, 05:34 PM
dan dan is offline
Default simplicity ? I know it's not a cub. but need help
My neighbor brought over his 2014 ish simplicity prestige, when trying to engage the mower deck it kills the engine. It has a reverse key that you have to turn to mow backwards and if you turn that and then the pto it will work, he says that he never had to do that before. just hoping someone has seen this before I start buying parts.
thanks Dan
Old 11-16-2018, 05:43 PM
You might have better results here ----- Simplicity
Roland Bedell
Buy: Made in the USA
Old 11-16-2018, 05:54 PM
dan dan is offline
Thanks for the link! Didn't want to join another forum but I will check it out.
Old 11-16-2018, 06:01 PM
You can view the topics (AFAIK) as a Guest.
Roland Bedell
Old 11-16-2018, 06:16 PM
ejl6658 ejl6658 is offline
If turning the key to mow in reverse does not kill the engine then it sounds like turning the key bypasses a switch on your hydro reverse pedal. I would start there by checking for a stuck reverse pedal switch or wiring issue.
Old 11-16-2018, 06:36 PM
cooperino's Avatar
Sounds like your the "neighborhood mechanic" if thats the case i would think you already have an idea that the issue is likely electrical. Get on a simplicity site, get the wiring schematics and get your meter out.
Old 11-16-2018, 07:17 PM
go here and enter your mfg. number..https://www.simplicitymfg.com/na/en_us/support.html
Up to 530 and counting...
Old 11-16-2018, 08:52 PM
dan dan is offline
thanks for the replies! "neighborhood mechanic" is about right! I try to do what I can for my neighbors but it always seems to happen when I have a lot going on! so I was hoping for the " my neighbor had the same problem and this was it" answer!! But we all know that never happens, so out comes the meter. thanks again!
darkminion thanks for the link!
Thread Tools
Display Modes
