Greg Rozar AKA- CubDieselFan
Old 10-09-2018, 07:49 AM
Mudrig150 Mudrig150 is offline
Default Engine removal
I'm going to be starting on the 1250's restoration soon, and I wanted to ask: Any tips for removing the engine? Mine's missing the lift hook and I don't want to damage anything trying to wrestle it out. Anything I should check with it out?
Old 10-09-2018, 08:29 AM
You have two options.
(A) Fabricate a Lift Hook, or
(B) Use brute force strength, and lift it out on your own.
Roland Bedell
Buy: Made in the USA
Old 10-09-2018, 08:31 AM
cooperino's Avatar
Bolt on a new hook.. Or a piece of chain through the bolt. Or do what I do.. Wrap your arms around it and just lift it out! Another method would be to belly wrap a strap right around the whole thing.
Old 10-09-2018, 10:18 AM
Terry C's Avatar
Terry C Terry C is offline
Just lift it out.
Or if you have a buddy, weld a 1/2in long piece of pipe to a old head bolt. Take a three foot or so long piece of smaller pipe that will go thru the welded on pipe and one person on each side of the pipe and lift it out.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 10-09-2018, 10:57 AM
twoton twoton is offline
If you're pulling the engine, figure on fixing the slop between the cross channel and the front axle too. So, block up the tractor frame, remove the front axle and roll it out of the way. Remove the ISO rail to oil pan bolts and blah, blah, blah.....
.....then lift the engine out.
Old 10-09-2018, 01:56 PM
Can't you just unbolt the cradle and then lift the engine out? My front axle doesn't really have play, so I don't need to deal with that.
Old 10-09-2018, 02:03 PM
cooperino's Avatar
Yes.. you can.. What he was saying is. Now is a good time to take care of the front axle with the engine out
Old 10-09-2018, 02:07 PM
Don't you have to take the front axle out to remove one of the cradle bolts?
I guess I'll remove it to check out the axle pin and change the arm on the steering box.
Old 10-09-2018, 02:19 PM
Yes you can, but... there are 'ears' on the front ends of the cradle rails where the snubbers are that can make it tricky to lift the engine and rails out as a unit. Especially if you are lifting it out by hand. If you have a lift/hoist its a different story.
Old 10-09-2018, 02:34 PM
The front axle has NOTHING to do with engine removal.
Roland Bedell
