Greg Rozar AKA- CubDieselFan
Old 08-21-2018, 08:54 AM
apex944's Avatar
apex944 apex944 is offline
Default Iso vs solid engine mounts?
1650 need engine mounts.
What are the pros and cons of doing solid engine mounts vs the ISO mounts?
How long does a new set of OEM mounts last?
Old 08-21-2018, 09:04 AM
And so the Great Debate begins.
I have a 1450 and I use the OEM Rubber Mounts and have NO issues.
BUT....it is your tractor, your time, your money, do as you see fit.
Roland Bedell
Buy: Made in the USA
Old 08-21-2018, 09:06 AM
We know you are new here, but research the site a bit. Several threads on this topic. Here is just one:
https://www.onlycubcadets.net/forum/...t=mounts+solid
Old 08-21-2018, 09:29 AM
apex944's Avatar
Thank you J-Mech. I have run a few forums and most definitely a "search first" guy.. I read a few threads including the one you linked but found them inconclusive. I *assumed* that I had missed the thread to end all threads. However now I see there are multiple issues, including just poorly balanced engines.
- Bill
Cub Cadet LTX 1045
Cub Cadet GT 2000
Old 08-21-2018, 09:32 AM
TNTs CC TNTs CC is offline
I just read that yesterday.
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights
GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder
3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller
1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers
Old 08-21-2018, 11:13 AM
I had two machines, at the same time, both 14HP,,
one ran as smooth as a sewing machine,,
the other almost shook you off the seat.
The first one would be perfect with solid mounts, the second really needed factory ISO mounts.
The engine dictates the needs more than anything, that is why there are multiple answers that are given,,,
Old 09-28-2018, 12:28 PM
nutzboutoldies's Avatar
nutzboutoldies nutzboutoldies is offline
This is interesting. Do you have an idea why the one ran smooth?
My 1450 vibrated so I tried the solid mounts. It didn't seem to help and now I'm if the solid mounts may be causing other issues so I'm considering to reinstall the ISO mounts.
Steve
1450
QA42A Thrower
44A Mower
Old 09-28-2018, 01:06 PM
Both engines appeared to be "factory sealed" (never rebuilt) and I never opened them,,,
so, I have no idea why the difference,,,
I just ran them,,
Old 09-28-2018, 02:34 PM
The old engines were mounted solid and they were fine. I SO mounts aren't going to make any difference. Only thing they did, was make the rider more comfortable because the vibration was less to the frame. Didn't do anything to help the motor. Piss poor design in my opinion.
Old 09-28-2018, 04:17 PM
Jon,
I always figured Iso's came along right about the time there was push for noise regulations so they prolly helped, along with the covers on the sides of the engine compartment, I'm thinking the Db rating was less.
I never put a meter to work checking tho'
Thread Tools
Display Modes
