Greg Rozar AKA- CubDieselFan
Old 08-15-2018, 12:06 PM
dbuck dbuck is offline
Smile Throttle stop
Anyone know anything about a throttle stop on the side of the carb. on a CH18S Kolher. I was told this by a long time CC mechanic, but can not remember what he said it affected as far as engine speed.
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 08-15-2018, 12:39 PM
It does not affect engine speed, only max throttle opening, thus a power limit.
Old 08-15-2018, 02:23 PM
TNTs CC TNTs CC is offline
It does not affect engine speed, only max throttle opening, this a power limit.
I thought I read that all Kohler did was to readjusted that screw to turn the 18hp engine into a 20hp version.
Any insight on that?
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights
GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder
3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller
1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers
Old 08-15-2018, 02:53 PM
I can't remember if it's a stop, or a screw.... but yes, that is correct. That is the only difference between a CH18 and a CH20.
Old 08-15-2018, 06:16 PM
mortten mortten is offline
Sam posted a picture of that screw some time back
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 08-16-2018, 04:24 AM
bugeye bugeye is offline
The stop is a screw on the left side of the carburetor. The air cleaner base must be removed to access. Round extended head. Move the engine speed lever to the wide open position and observe the throttle plate. If installed, the stop prevents the throttle plate from being wide open. Just remove the screw to allow the throttle plate to open.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
Old 08-16-2018, 02:02 PM
Smile
Thank you everyone for your replies. I will go down to the shop later an check on making a CH18 into a CH20, using the throrrle stop.
Old 08-20-2018, 11:55 AM
Smile
Finally got around to checking the throttle stop on the CH18. It is not on the carb, their is a self tapping screw in the throttle control plate, that limits the throttle plate from being wide open. This screw comes up from the bottom, therefore you would have to remove the control plate to remove this screw. As my Ch18 in my 1864 has pently of power, it will stay as is.
Old 08-20-2018, 01:02 PM
This is how it was on my engine.
Old 08-21-2018, 07:54 AM
mickb72 mickb72 is offline
Yep and it's gone on mine now. Still need to reset the governor though. Mike
