Greg Rozar AKA- CubDieselFan
Old 11-08-2018, 01:39 PM
Terry C's Avatar
Terry C Terry C is offline
I sand my grills and wheel weights with a DA sander. Just took the really high peaks off.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-08-2018, 02:31 PM
Merk Merk is offline
Sent you a PM.
Project Uncle Dick
Cub Cadet 70
Old 11-08-2018, 06:33 PM
There are aluminum ones out there, and are smooooooth, just need to find one though...
Up to 530 and counting...
Old 11-08-2018, 07:03 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
The casting has "texture", not pits, sheesh!!!
Old 11-08-2018, 07:40 PM
TNTs CC TNTs CC is offline
How is removing the casting texture on the grille the tractor came with "restoration"???? Sounds more like a modification to me...
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights
GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder
3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller
1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers
Old 11-08-2018, 09:01 PM
john hall's Avatar
What he said. Castings rarely "pit", just clean the rust off, slap some primer and paint on and go.
Here is one I did when I was 18. We used wire brushes (lots of them) to clean it.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 11-08-2018, 11:29 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
The lower casting is supposed to be rough... that's how cast iron parts are.. wire brush it, prime and paint!
Jay
Proud owner of the following:
Old 11-18-2018, 03:27 PM
Tiny's brother Tiny's brother is offline
Default Body fill
Despite my better judgement I’ll chime in to this controversial subject: similar to painting a Cub Cadet - Green. What you can do is 2-4 coats of high build primer and / or a skim coat of 3M Premium Glaze or “Body Fill” also EverCoat Rage Ultra is some good quality filler. Do not buy USC or Bondo brands as they are a nightmare to sand. Spend a little extra, a quart will be more than enough. Start with 80 grit then work up to 320 or higher to avoid sand scratches showing in the final paint. It’s not for the average re-paint but if you want the best quality then you have to do what no one else does.
File Type: jpg AE353F8C-5094-43F1-B962-2342F2D5D00D.jpg (29.5 KB, 76 views)
