#21
Read an old Ford 8n forum. Beat into your head from day 1. Negative ground =negative wire to points, positive ground=positive wire to points from coil. Will work either way but that claim is the best. Were positive ground to start with but many have been changed from po error. I won't even get into resistors. I'm left handed too. Mike
#22
I asked how a coil fires ,what the components are doing to accomplish it , and you go into how why electricity flows I ve known since I was 17 |
#24
Good post there Vrobert.
#25
#26
Let's have the simple explanation. It may be more useful than my nitty-gritty details but I promise I didn't make this stuff up.
Rusty 149 project with: QA42 snow thrower 38" deck Barn fresh 1811 with: 44c mowing deck QA42A snow thrower 42" snow blade |
#27
BTW when a wire passes a magnetic field making current is called a alternator |
#28
Mmmmmm.. Almost correct. What your describing is Faraday's Law. Its based on induced EMF. There needs to be a little more happening than your describing such as the conductor need to be spinning within opposing magnets in order to work. EMF is the Electro magnetic force thats created.
#29
A collapsing magnetic field will also induce voltage in a wire, similar to a wire passing through a field like what happens in an alternator (or generator). I'm pretty sure I understand the basics but there are plenty of tutorials on the web so maybe a little self-study is in order.
#30
Thought without Jmech it was going to be a paradise of people getting along.
Guess not quite.
