Greg Rozar AKA- CubDieselFan
Old 07-13-2018, 07:17 AM
goodintentions goodintentions is offline
Default Trying to I.D. translatable MFG.
I have a Cub that has no markings and the I.D. decal is gone. I believe it to be a 3225 that someone has replaced the Kohler Command 22 HP with a 23 HP.
The trans-axle model # 618 -3209 is one I want to find out who the MFG. is. I contacted Hydro Gear and they say its not theirs.
Does anyone know who the MFG. is ?
Thanks for the help.
Old 07-13-2018, 07:23 AM
First, welcome to OCC......
The information you supplied offers no clues. How about posting a picture.
Roland Bedell
Buy: Made in the USA
Old 07-13-2018, 08:39 PM
There should be a tag under the hood on the right side and another on the right side of the frame.
Up to 530 and counting...
Old 07-14-2018, 07:54 AM
Hydro-Gear made all of the 3000 series hydro units. It will have a BDU-21L pump.
Here is a link to the manual if you need it.
http://www.hydro-gear.com/b78c82181d...N-50327_P6.pdf
Old 07-14-2018, 02:01 PM
Default Cub Diff
The differential has a stamped MTD 3 blades of grass logo on it and the unit is some type of metal because the magnet sticks.
IF Hydro Gear builds the pumps, then who builds the diff ? Hydro Gear told me the 618 - 3209 model number was NOT theirs.
I have absolutely no I.D. decals anywhere on this unit other than the one on the hump on the floor pan which is a decal in a circle and says "shaft drive"
That is why I thought if I could I.D. the trans-axle with its model and serial number I would be able to figure out this Cubs model. The guy I talked to he Cub corp was not real helpful. In fact he told me ALL Cubs had the I.D. tags under the seat, but the 2006 2554, and 3184 both have them behind the R.H. front wheel under the starter on the frame.
Everything pointed to this being a 3235, but those had a deck height knob on the floor pan, mine only has a small window.
I appreciate your help, Thanks.
Old 07-14-2018, 02:40 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
The hydro unit is mated to the axle/diff assembly.
So the axle/diff could be a Peerless, etc.
You sure that number 918-3209 is not 918-3203 ?
The latter being the part number for a diff cover on a 3184, 3186, 3205, 3206, 3208, 3225 and 3226.
Per partstree.com
Old 07-14-2018, 03:00 PM
We still don't have a picture of this machine.....
The transaxle assembly was made by MTD. It is their own design. Used the same one in several tractors, so not a good way to identify the tractor.
If this thing is missing all the serial tags, I bet it's stolen. Maybe you don't want to know what it is.
Old 07-14-2018, 03:39 PM
Hydro -Gear only made the pump. All other stuff is made by Cub.
Here is a pic of a 3165 rear tag. This had nothing to do with the model of the machine other than it is the part number for that piece.
My 3205 is missing the chitty decal tag for the model & serial but I have it. It fell off but I found it. I guess they were too cheap to put a metal tag on a $7000.00 lawn mower.....wonder why they can't compete in todays world?
You need to post a pic of your machine. There were several changes that they made before they threw in the towel on building a good garden tractor.
Does it have an aluminum or cast iron rear, slotted wheels, tilt wheel, how many slots are in the hood, where is the solenoid for the evac located, does it have the cutout for the rear pto in the rear hitch plate? Lots of other stuff was changed too.
It's okay, I still love my 3k's
Old 07-14-2018, 04:15 PM
Default Pics for Cub
I will get some pics and post them. I was told by a guy at Cub corporate that Cub put the I.D. Tag under the seat.
A NEW seat was installed before I got it, if that is the case the I.D. tag was not transferred to the new seat, but why would Cub put a piece of information so valuable on something was was going to be replaced soner or later ?
As I mentioned earlier the 2006 GT 2554, and 3184 both had I.D. tags on the frame behind the front R.H. wheel under the starter.
The model number of the trans-axle is 618 - 3209.
Thanks for everyone's help. I will get those pics on as soon as I can.
Old 07-14-2018, 04:46 PM
The model number is under the seat. Not on the seat. Under it....
Again, that number 618-3209 is a part number, not a model number.
