CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 08-08-2018, 06:40 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
Default Looking for dimensions
I've been searching for the oil pan bolt hole center dimensions for a Kohler K-301 AQS engine. I don't have an extra oil pan and wanted to make a template to hold the engine rails in place to weld in the brace modification.
Does anyone happen to have this info available?
Randy
1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift
Old 08-08-2018, 06:48 PM
Can't you just measure the pan you have? Engine has to come out to do the mod...
You really need to bolt it to an actual pan. If you measure, make a template, weld it up, then go to put it on, what if your template was wrong? At the very least, you need to check the template against an actual pan to confirm fitment.
Old 08-08-2018, 07:00 PM
Bullwinkle:
Stay tuned, I am sure someone will come along and answer your question, and supply you with the information you are seeking.
Roland Bedell
Buy: Made in the USA
Old 08-08-2018, 07:02 PM
bllwnkl's Avatar
Somehow I figured I would get this answer, and I also figured it would probably come from you!
My first thought was that I wish I had an extra pan so I wouldn't disturb a non-leaking sealed oil pan and make more work for myself. That's why I thought of a template. So...I guess I need to search for an oil pan gasket.
Randy
Old 08-08-2018, 07:04 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
pm sent
Queen Of The Quietlines!
Old 08-08-2018, 10:14 PM
Do yourself a favor, bolt it to your pan,or spare pan.
Oh and they "pull" when you weld them.
Nothing wrong with bolting it to your pan while the engine is out.
Just drain the oil, flip it over and have at it.
BTDT.
Old 08-08-2018, 10:19 PM
BTDT.
That's what I said......
Thread Tools
Display Modes
