Greg Rozar AKA- CubDieselFan
Old 10-24-2009, 02:05 PM
Since we're discussing oil. I'm going to have a dilema this winter. During the winter here it inconsistently goes anywhere from the low 20's to upper 30's even 40's throughout the days. What do you guys recommend for my oil type. 10w30 or 30wt? I'll be using the 782 with blade and I had to use it more than i expected to last year and this year is expected to be more snow. It has the KT17 Series II. Oh, it'll be in the unheated garage.
I have a similar problem...the temp hovers around 30 degrees during the winter, and I also rarely put more than 10 hours on during the winter. I don't like changing oil after 10 hours, as it seems like a waste, but these things seem to burn thinner oil faster when it's warmer out. My solution is to run Shell Rotella T 15w40 year-round. It worked great in my diesels during the winter, so we'll see how it does in my 782 this year.
Old 10-24-2009, 06:50 PM
aagitch's Avatar
aagitch aagitch is offline
What does the EO mean when you guys mentioned Shell Rotella 30wt HDEO? I've seen the 30wt HD at the stores but not the EO part.
Old 10-24-2009, 11:41 PM
CubQuest CubQuest is offline
EO = Engine Oil
Old 11-04-2009, 08:38 PM
MrMac's Avatar
MrMac MrMac is offline
Default summer and winter
Mobil 1, 5W30,BUT,I plugged all the leaks,and it doesn't burn.(M-18 Kohler)
Old 11-05-2009, 10:11 AM
MFP8055 MFP8055 is offline
My 2 cents on oil: I run Castrol GTX 10-30 in everything. My tractors see use year round (upstate NY) and oil gets changed at about 25-30 hours. My two Subaru Outbacks have 261,000 and 264,000 on them with no engine work on either using the Castrol and changing at 4,000. From my perspective the synthetics seem to be specified in high engine heat applications. Newer Corvettes will have their warranty voided if dino oil is used for instance. The longevity is an added bonus. My simple rules: use good stuff and change it regularly.
IH 1650, CC 1210, 1610 and Bolens 1257
