Greg Rozar AKA- CubDieselFan
Old 08-18-2018, 06:01 PM
sorner's Avatar
sorner sorner is offline
Default Cub Cadet 73 38” deck belt sizes?
What size belts does a 73 with 38” deck take? I’m working on one for a friend and it needs belts but I can’t find any links that work on this site.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 08-18-2018, 06:12 PM
Here you go
http://cubfaq.com/belts.html
Old 08-18-2018, 06:15 PM
Cubcadet.com should still work......
Old 08-18-2018, 07:54 PM
Here is the belt and blade PDF file.
http://www.cubcadet.info/Manuels/Bel..._1947-2004.pdf
Up to 530 and counting...
Old 08-18-2018, 08:54 PM
sir_lancealot sir_lancealot is offline
Here is the IPB for your deck and tractor combo.
https://www.cubcadet.com/equipment/A...6-A/0062660003
Old 08-20-2018, 09:16 AM
sorner's Avatar
That link does work, but it only gives the IH part number, and I was looking for the size. cubfaq.com got me what I needed, thanks Alvy.
#2 cart
Old 08-20-2018, 09:22 AM
Oh good grief.
Look... if you plug it in Google, like a million links come up, and oh my gosh! About half have the size listed too!!!
https://www.google.com/search?q=IH-4...hrome&ie=UTF-8
Come on.
Old 08-20-2018, 09:31 AM
Matter of fact, if you click "add to cart" on the CCC website, it also gives you the belt size. I thought it did, I just went and checked.
Also, you do know that like every part store that carries belts has a chart. If you are going to buy one locally, which, if you are fixing a tractor for someone else, I assume you aren't going to order a belt online.... you can just call the store and they can tell you what belt you need.
Old 08-20-2018, 09:40 AM
sorner's Avatar
Well I figured I would just ask here, and get a quick answer from the experts. I got the answer... and lesson learned... again.
#2 cart
Old 08-20-2018, 09:41 AM
My point is, you had all the info you needed. Why should we have to go look up the length and give it to you? We did the same thing you can do.... and I'm sure you have been here long enough to have seen all those links before.
