Muffler Clamp
Sorry for such a trivial post, but anyone know where I can get a decent muffler clamp? Tried ordering what I thought was OE, but the clamp I got was way too small. Found a 1-1/2 in motorcycle exhaust clamp, but its too big. My FLAPS doesn't have anything this small. Since I'll be ordering something anyway, might as well order something decent. Any suggestions?
IMG_20190317_161755.jpg |
U-bolt clamp. Find them at your local automotive store.
Justin |
If you switch to stainless muffler bearings, instead of OEM steel bearings, the larger clamp that you have will work,,,
Keep the stainless bearings well lubed with graphite,,, |
Your a Nut! lmao
IF......you want OEM original, you will need Kohler 237543 Exhaust Clamp.
It should be noted:
In extensive studies at prestigious Jay Bee weld institute, it was discovered that the encapsulated sinusoidal oscillations produced in the muffler will cause extensive brinelling of the stained-lips bearing races, if lubed by graphite/ky jelly mixture. It was their findings that it is always better to lube with a 50-50 mix of Skoal bandit/ marbled misery Earl. |
Like the muffler..... I'm baffled how all this stainless bearing came about!
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
It was a bit of humor.....that's all.
wait until you start looking for stainless muffler bearings,,, The last one that I found was in Home Depot,, hanging next to the left handed adjustable wrench,,, |
you tube muffler bearings. When you get done with that try blinker fluid
