Greg Rozar AKA- CubDieselFan
Old 03-16-2019, 07:44 AM
ccpullin ccpullin is offline
You may have a ground issue. I believe there are green ground wires attached to the battery support frame and also on the right side of the engine support by the fuel pump. I have seen the entire battery support frame loose its ground as it uses the same 4 grill retaining bolts for it. There are several electrical items grounded to it also. I usually run a brand new ground wire from the engine to the battery support to cure. Be sure to scrape the powder coat paint off where you attach the ground and also check those ground wires for a good connection behind the terminals as they have used star washers for making the ground! Also check the plug in on the clutch for a good connection.
Old 03-16-2019, 11:31 AM
shovelhead shovelhead is offline
I will check these trouble points. Thank you!!
Cub Cadet Original, 2-100's, 71, 122, 123,
106, 107, 1541 and 2182 Super.
Old 03-16-2019, 04:40 PM
Would any of these grounding issues explain why the lights come on when I turn on the pto switch. At this point, the pto doesn’t even try to come on. Just dim flickering headlights.
Old 03-16-2019, 05:45 PM
CubDieselFan's Avatar
When I first got my 1572, I had pto trouble like you have minus the headlight problems. Traced it down the the rear pto jumper plug. It was corroded down inside and would drop enough voltage for the pto to turn off.
Old 08-11-2019, 06:33 PM
Gentlemen!!
I sincerely apologize for not getting back on here to close the loop.
It ended up my front pto clutch was shot and that was the culprit.
The flickering headlights was a ground issue and was an easy fix.
Thanks to all who responded!! The information that everyone
volunteered, was a great help!!
Again, Thanks to Everyone!!
